Results 1 to 7 of 7
    Reputation: Slobberdoggy's Avatar
    Thread size check - chainring bolts?
    Parks website says they are 8mm x.75 Is this correct? I need to get a tap to clean some threads on my cranks. Shame parks jumbo tool kit doesn't include this size.
    thanks
    Reputation: shiggy's Avatar
    Dec 1998
    I would just replace the bolts
    mtbtires.com
    No I have to clean up some messed up threads with the tap - i'm not changing the size or anything.
    edit: Threads for the inner ring.
    Nobody knows? I would think this is a common tool at bike shops.
    Answer
    Another lovely reply to my own post,
    It is defiantly .75 and the width is like 7.8mm so I guess that means 8mm.
    Now I just need to find the tap.
    Reputation: jakerollo's Avatar
    I just cut threads in a truvative crank for the small chainring. It is a 104mm bcd crank but the surface for 64mm bcd was there so it was quite easy. I am quite sure that it is 8x0.75mm but my chainring bolts does not fit. I will try later with some other bolts.
    It migtht be the truvative bolt + nut that is not made to the standards of a M8x0.75mm.
    Update - The truvative bolts are not made to the standards. All my other chainring bolst fits nicely.
    So - M8x0.75m it is. Long live the metric system.
Members who have read this thread: 4
