Results 1 to 3 of 3
    Aug 2005
    Are their really 9-speed and 10-speed Shimano front derailleurs?
    So I'm shopping on this website for a front derailleur and see this description for a Shimano SLX M660‑10 Top Swing 10s Front Derailleur:
    - Compatible with Dyna-Sys drivetrains for lightness, tight gear ratios, and efficient chain movement.
    - Swing action is top-swing.
    - Compatible with 10-speed cassettes.
    - Maximum capacity is 18T.
    - Top-middle minimum capacity is 10T.
    - For 42-32-24T.
    - Dual pull cable routing.
    - Chain line 50mm
    - Chain stay angle is 66-69 degrees.
    - Multi-clamp (28.6/31.8/34.9mm).
    I thought all Shimano LX, SLX, XT and XTR front derailleurs didnt care what cassette speed you had?
    And can anyone clarify what they mean by "10T" and "18T" capacities?
    I'm just messing with you
    Reputation: wv_bob's Avatar
    I've been wondering the same thing about 9s to 10s compatibility.
    Capacity is the difference in teeth between consecutive rings. You need at least 10t difference in your big and middle rings, and no more than 18t difference between big and middle, and middle and granny.
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    Aug 2005
    Quote Originally Posted by wv_bob View Post
  1. Differences between 9 speed and 10 speed X0 rear derailleurs
    By ryguy135 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-07-2017, 08:52 AM
  2. Shimano XT 10 speed (rear) with 9 speed (front), does it work?
    By TheMajor in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-22-2012, 06:40 PM
  3. Are SRAM and Shimano 10 speed shifter/derailleurs interchangeable?
    By awai04 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-06-2011, 09:47 AM
  4. Replies: 1
    Last Post: 09-16-2011, 03:27 PM
  5. Do 10 speed Shimano GS derailleurs work with 36T cassettes?
    By womble in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-09-2011, 08:07 AM
