Results 1 to 3 of 3
    Reputation: flipnidaho's Avatar
    Teflon tape on BB threads???
    I have a creak that i'm trying to isolate. I'm at the point of using teflon tape on the BB. It's an XTR (generation before current) on a Ti frame. I typically use anti-sieze instead of grease and torque to specs. My question is, if I use teflon tape on the threads, do I still use anti-sieze as well? Also do the torque values change if I use teflon tape?
    Thanks in advance...
    Reputation: VT Mike's Avatar
    Quote Originally Posted by flipnidaho
    As you thread the cups into the shell, some of the teflon tape will get pushed back. So the Aluminum cup will be in contact with with the ti shell, at least a little bit. I think I would still use the anti-sieze along with the teflon tape. The regular torque spec should be okay, as long as you don't put the tape on too thick.
    POG
    POG is offline
    Pudgy Old Guy
    I use both.
    Put a light coat of grease on the threads and wrap the tape over it. Be sure you wrap the tape in the direction of the threading if you know what I mean.
  1. Lightweight, durable ISIS BB?
    By 1speed_Mike in forum Weight Weenies
    Last Post: 09-01-2004, 01:07 PM
  2. LocTite or grease for BB cup threads? (ES-70)
    By PiroChu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-29-2004, 10:26 PM
  3. teflon tape on bottom bracket installation
    By Patchito in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-28-2004, 01:45 AM
  4. I'z got a BB thang goin on...
    By jrm in forum Passion
    Last Post: 04-22-2004, 08:56 AM
  5. Teflon tape for BB??
    By Kaparzo in forum General Discussion
    Last Post: 03-22-2004, 10:20 PM
