Results 1 to 5 of 5
    Switching from an 11-32 to 11-34 chain length?
    I am currently running an 11-32 cassette but I am switching to an 11-34 will the chain stay the same size or will I need to add or remove links?
    Vaginatarian
    should be fine unless its at the limit now
    I dont think its at the limit I wasnt told it was. I have only been involved with mountain bikes since last year after doing bmx for 14 years so I am still learning. I have pretty much got everything down except chain length, adjusting/installing derailluers, and bleeding hydraulic brakes.
    Vaginatarian
    http://www.parktool.com/repair/readhowto.asp?id=26
    use the largest cog, largest ring method to check
    Quote Originally Posted by Prostreet513
    I did that and the length was fine when I went to 46 on the front I needed one more link...
    Just make sure that the RD can handle the big to big combo and everything will be fine.
