Results 1 to 5 of 5
    Mar 2006
    Suitable Grease for Shimano Clutch?
    My Shadow+ feels a little notchy when the cage travels through its range, so I thought I'd try lubricating the clutch as described here:
    http://techdocs.shimano.com/media/te...9830789046.pdf
    I don't have any of the shimano grease on hand, and can't find it online. I was thinking I'd try some Chris King grease that I have. Any recommendations otherwise?
    Theoretically, you'd want a temperature resistant grease like the quoted internal gear hub grease. Most automotive bearing grease would be suitable.
    Oct 2007
    The clutch on my m786 wasnt fully releasing - moving backwards towards the rear of the bike. The cage was hanging mid stroke and causing massive slack in the line resulting in dropped chains on my 1x10, this was happening with the clutch on or off. Lubing the inside of the clutch case with phils tenacious oil cured my problem.
    replying to a dead thread because this was the first result on 'lube shimano clutch'
    Reputation: PerthMTB's Avatar
    Just be careful as there's three distinct areas inside a Shimano clutch that need lubing, and one has very different requirements and therefore different lube.
    While the clutch band and cam mechanism need a thick sticky grease that's going to stay put, the inner workings of the clutch drum has minute pawls and roller bearings, and needs a really thin oil so it doesn't gum up.
    Reputation: DeArman's Avatar
    Jun 2014
    My clutch was beginning to feel like crap, so I took it apart and re-greased it with Slick Honey, and the clutch HATED it. Tore it all apart again and refilled it with pink Mobil 1 grease and it is MUCH better. To truly grease it though you have to actually take the clutch out and apart as stated above
  1. Has Anyone Else Broken a Shimano Clutch RD?
    By Salespunk in forum Ibis
    Last Post: 06-03-2014, 01:47 AM
  2. New Clutch Derailleur for 1X10. SRAM or Shimano?
    By integral in forum All Mountain
    Last Post: 05-13-2014, 02:44 AM
  3. Replies: 6
    Last Post: 10-15-2012, 10:11 AM
  4. New Clutch Derailleur for 1X10. Shimano or SRAM
    By integral in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-30-2012, 09:21 AM
  5. Alternate Grease for Shimano hubs?
    By jtrops in forum Internal Gear Hubs
    Last Post: 09-04-2011, 02:09 AM
Members who have read this thread: 7
