Results 1 to 2 of 2
    Reputation: Thucydides's Avatar
    Sugino Impel 150X crankset?
    Have any of you tried the Sugino Impel 150X crankset? I have a BB UN72, which is a square taper, 110mm bb and it appears that this may be one of the only cranksets out there. I need to replace my chainrings and was planning on buying Deore rings, but the sugino crankset would be cheaper. Thoughts?
    Thanks for the help.
    -Adam
    Reputation: Wombat's Avatar
    I buy the Shimano m440 cranks (the lowest Shimano cranks with removable rings) and then use only the chainrings on my LX cranks. This usually works out at less that $35 and you can sell the cranks (without rings) after you have finished. I haven't found a cheaper way of doing this.
    Tim
