Results 1 to 2 of 2
    Stylo Oct 1.1 install
    When this crankset is installed properly, is the drive side supposed to touch the side of the bearings on the bottom bracket? First time use of a Truative crankset. I'm running this as a 1x9 and there is a bit of a gap between drive side crank and the BB. It doesn't assemble any closer to BB, which is making the chainline straight on a the third smallest cog.
    Any experience with these? Is this normal? Is it possible to straighten out the chainline, or is that just the way it is?
    W
    slight gap about 2-3mm
