Results 1 to 3 of 3
    Did I catch a niner+?
    Stylo 1.1 put 32/42?
    So I am building up a Vassago Fisticuff and have this crankset laying around and figure I will use it. Is there enough space on the bolts to not have any rubbing between the two or do I need to get some small spacers? I assume these are just a Stylo 3.3 with the small chainring holes sealed up or not drilled.
    Would be using a 32t/42t XT chainrings I have laying aroundc.
    dwt
    dwt is offline
    Reputation: dwt's Avatar
    I have 2 Stylo 1.1 cranks, one on SS and one on 1 x 9.
    Though I haven't done your 2 ring idea, I think it makes perfect sense and there's no reason I can see that it won't work fine.
    Let us know
    Old enough to know better. And old enough not to care. Best age to be.
    It does work. The XT inner ring wont fit due to the way the composite is designed around it hits the arms. But I did use the original inner ring albeit heavier and the XT 42t outer ring. Just waiting for the frame rest is all setup.
