Results 1 to 7 of 7
    Dec 2009
    Stuck Chainring bolt...to drill or not to drill?
    I stripped a torx bolt on my slx crankset while switching from a 3x to 1x setup. I was able to get 3 of the 4 bolts out but the last is a bugger. I have tried adding WD-40 to the threads and using a fresh hex wrench to no avail. I am thinking that I will have to drill out the bolt. I have never done this before. Would someone provide there two sense on how to do this. Can you recommend a drill bit? I am assuming the bolts are alloy given how easily they rounded out.
    Reputation: Shalom's Avatar
    Nov 2008
    They are alloy. Before pulling out the drill though, try the next size up torx bit. Tap it in gently with a hammer - to get it wedged in there good and proper. Then see if that will come out. If not, drill.
    If you are not confident drilling it, take it to your LBS. They should be able to do it for beer.
    Reputation: 69erEverything's Avatar
    Mar 2012
    Drilling sucks and takes too long. Use a cut-off wheel with a dremel. Zip
    99% of the problems and questions posted here would be answered if people actually walked into a bicycle shop and asked
    Use a larger EZ-out chucked into an impact wrench. Guarantee it'll come out. You can use it like you are supposed to, but expect to smash knuckles on the chainring when using the nut wrench.
    For that matter, use an impact wrench to remove chainring bolts, period. Nothing easier...just make sure the bit is seated in the bolt before you start it up.
    You can drill it out, if you'd like, though. Another option is to grind the head off of one side and give it a whack to remove it.
    Dec 2009
    Thanks...the next size up worked really well! surprisingly easy.
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by Shalom View Post
    Cash would be better, the shop can't pay rent with beer. Beer is always a good tip though, or a bribe to cut your bike ahead of the repair line!
    An Easy out might do the trick.
    Nov 2008
    True, but in my experience, beer is appreciated for small and relatively easy jobs like that. And it tends to encourage a lasting relationship
  1. Want to drill my RD's
    By Floyd298 in forum Fat bikes
    Last Post: 10-21-2013, 03:27 AM
  2. Drill Odis for fender?
    By skankingbiker in forum Singlespeed
    Last Post: 12-31-2011, 09:14 AM
  3. Drill the cable stops on an EG
    By Boylerules in forum Titus
    Last Post: 11-09-2011, 02:14 PM
  4. Drill valve hole
    By BARAvnzla in forum Wheels and Tires
    Last Post: 08-04-2011, 10:40 AM
  5. Can I drill my Kings to 9mm for RWS skewers
    By jeremy524 in forum Wheels and Tires
    Last Post: 02-15-2011, 04:35 PM
