Results 1 to 22 of 22
    Feb 2010
    strongest cassette
    i searched the forum and wasn't able to come up with anything relevant.
    i want to get a good cassette that won't wear out quickly. which make/model of 11-34 cassette is built to last a long time? price and weight not important.
    ups and downs
    Cassette life is at least 75% related to how often you change your chain. If you keep the chain under the 0.5% stretch/wear, any decent cassette will last a long time.
    A Mountainside=My Therapy
    Reputation: ColoMtb20's Avatar
    most of the durability has to do with the hub assembly, not so much the cassette.
    Vaginatarian
    shimano XT is pretty decent for the money
    if moneys no object you can get a full ti for $300 from action tec (individual cogs though so might tear up your freehub)
    Former Bike Wrench
    As mentioned above, cassette wear is directly related to your chain. Using the ruler method, if you replace at 12 1/16" you can get many miles on a cassette.
    I have found almost zero difference between Deore/PG 950 cassettes up to XT/PG 990 cassettes as far as wear. I have noticed an actual difference in chain wear from cheaper chains to better chains...and since chain wear is what kills cassettes, you should really be asking what is the longest wearing chains.
    Feb 2010
    thanks for the informative posts everyone.
    Sorry I misunderstood your question.
    Quote Originally Posted by rockyuphill
    Good lord I would blow through 20 chains a year if I changed a 0.5% wear...
    I run the chains out to 1% plus wear, I get about 3 to 5 chains per cassette...
    I run the shimano CN-7701 chain that I buy from jenson for $25 a pop....
    I run the shimano 4-part XTR cassette with the ti sprockets..Chain Reaction for about $150 a pop.
    Right now I use about 2.5 chains per year and a cassette lasts about 2 years...
    That is about 7500 km/yr of riding year round through the long cold salty winter.
    Quote Originally Posted by mtnbiker72
    Keep hammering maybe everybody will believe you one day.
    Reputation: damnitman's Avatar
    theoretically...
    ...speaking, do you want a chain that is stronger than the cassette (which would then wear the cassette to the chain) or do you want a cheap POS which wears to the chain to the cassette (a chain that you can afford to replace once a month)?
    If Huffy made an airplane, would you fly in it?
    Vaginatarian
    Quote Originally Posted by damnitman
    if that was the only problem with cheap chains you would have a valid point but what would the chain be made out of to be weaker than aluminum cogs in a cassette?
    and how strong would such a chain be?
    as it is
    you can buy a cheaper cassette that has steel cogs and you can buy a cassette that has all Ti cogs, but you're still spreading the wear over 9 cogs.
    replace your chain as soon as it wears to 1/16"-1/8" and your chain rings and cassette will last through many chains
    Hunh?
    I am admittedly not the most technically proficient guy around...but aluminum cogs in a cassette? They make alu carriers that hold the steel or ti cogs together, but I can't seem to recall any other alu components in a cassette...There are Alu chainrings up front, but they are typically heat-treated to increase hardness and resistance to wear...alu cassettes??? anybody wanna enlighten me?
    Vaginatarian
    http://www.torontocycles.com/
    scroll down toward the bottom
    actually this is the only one I could find, except for road , Half asleep yet sorry, I editied my original post
    Former Bike Wrench
    Quote Originally Posted by jeffscott
    I've said it before and I'll say it again...take your ignorance elsewhere, I have YEARS of experience over you and yet you continue to provide clueless and down right wrong answers.
    Grow up loser
    Underskilled
    Reputation: CaveGiant's Avatar
    If you had asked this question in the Clyde forum you would have got a string of answers.
    All of them being Shimano XT.
    Clydes (including me) can fold over the rings on high end SRAM, XT wears slowly and is VERY VERY strong.
    Can't do better from mainstream (exotics like Actiontek may be better, but ouchy price)
    Former Bike Wrench
    Quote Originally Posted by dan0
    Aluminum cassettes and Freewheels go back many years, Campy did them for road racing way back and Real was doing one piece CNC's 8 speed cassettes in the late 90's. It's basically a weight weenie thing for racing. Aluminum cassettes will not last long (most gears at least, larger 30,32,34,36t gears should be OK) but if your looking for the ultimate weight advantage, they provide an edge.
    I Have Cookies
    Reputation: ae111black's Avatar
    Dec 2008
    Grow up loser
    LOL!!
    The most important thing is what God thinks about it. He will have the final say. Joshua Stinebrink
    ____
    Kimo
    ballbuster
    Reputation: pimpbot's Avatar
    Yeah....
    Quote Originally Posted by jeepsrt8
    I've had better luck with Shimano. I get years out of Shimano cassettes, where I would hardly get through one year on a SRAM before it would start sounding like a cement mixer back there. All the Shimanos are pretty much the same, except the XTR with has some Ti. Oddly enough, the Ti wears faster. The reason to go XTR is if you want to shed that last bit of weight.
    Former Bike Wrench
    Ti has 1/2 the density of steel so it actually makes sense that it would wear faster...it's also why on XTR it is only the 4 largest cogs are Ti. That said, I had a 8 speed XTR cassette with the Ti largest cogs that lasted YEARS with regular chain replacements.
    g3h6o3
    Reputation: PissedOffCil's Avatar
    Oct 2007
    Not sure about how density really affects wear. It's not because a material weights less that it is less durable. I think you are confusing density and strength... I'm no expert so feel free to rectify.
    That said, yes ti wears faster than steel but not that much. Compared to alu though it's way more durable, yet the density of ti isn't that much more than alu.
    Check out my SportTracks plugins for some training aid software.
    I Have Cookies
    Dec 2008
    I pretty much only use Shimano cassettes now days, I'm a bug guy and I tend to break things (not so much any more) but fot your moneys worth I'd say stick with SLX or XT and you can't go wrong, (Strong=Cheap=Decent Weight)
    ____
    Kimo
    Former Bike Wrench
    Quote Originally Posted by PissedOffCil
    If you used just raw Ti, it would wear much faster than steel. But manufacturers use Ti alloys such as 6Al/4V Titanium Alloy and then heat treat it to a very hard finish in chainrings and cogs, which makes them quite durable. This, more than the actual raw material, makes the chainrings and cassettes so expensive.
