Results 1 to 8 of 8
    Reputation: detsortehul's Avatar
    Idea! Stripped splines on XD cassette: How to fix :-)
    I screwed up and stripped the splines on my SRAM XG1150* cassette when removing
    * 11 speed, XD driver, pinned.
    I was not able to find a solution here and therefore I created this short and easy walkthrough.
    It works for the pinned cassettes. I do not know about the higher end cassettes.
    Step 1:
    Use your vice and grip the cassette on 11th sprocket (largest).
    Use an angle grinder and cut all pins connecting sprocket 3 and 4 as well as sprocket 10 and 11.
    The central sprockets (4+5+6+7+8+9+10) are now free to rotate as one unit.
    Step 2:
    Grip the cassette on sprockets 10+11 with your vice so that the central sprockets are securely fixed.
    Cut the central sprockets in half and remove the sprockets.
    Step 3:
    Grip the cassette on sprocket 11 with your vice.
    Use a polygrip plier and grip the central free area of the cassette body and unscrew.
    Step 4:
    Wipe off the sweat of your forehead and enjoy favorite beer
    Central sprockets removed:
    Stripped splines on XD cassette: How to fix :-)-20180701_190430.jpg
    Central sprockets cut in half:
    Stripped splines on XD cassette: How to fix :-)-20180701_190437.jpg
    Freehub cleaned and ready to install again
    Stripped splines on XD cassette: How to fix :-)-20180701_190852.jpg
    May 2016
    how did you strip it?
    :O
    Quote Originally Posted by randum View Post
    :O
    100% my own fault: I was changing the cassette on my second bike and did not notice that the end cap hindered the lock ring tool from engaging fully. When it only engages 50% the splines are stripped...
    May 2016
    thanks for letting me know, i would have probably done the same thing xD
    i feel the pain tho, sh*t has happened to me too
    Reputation: gmats's Avatar
    Apr 2005
    Whoa. Yeah. Been there (Not with that) but with other stuff. Good job there. I see the Stans, duct tape and other stuff in the background of your pic.
    Jan 2009
    The exact same thing happened to me, so I thought I'd finally found a good excuse for purchasing an angle grinder. Then it turned out that on the XG-1195 (X01) cassette you can simply pop cogs 1-10 off by disengaging the pins that connect them to cog 11. Then just take the pliers to the freehub body and you're done.
    Here, diagonally!
    Reputation: JACKL's Avatar
    Quote Originally Posted by detsortehul View Post
    That right there is art. It speaks to be, although what it is saying remains elusive...maybe a representation of the circle of life being broken...
    Quote Originally Posted by JACKL
    ... and this is poetry :-)
    I sent the remains to the steel bin in the recycling facility: "From Steel You Came, and To Steel You Shall Return".
  1. Culprit: Sunrace Cassette or Aluminum Freehub Splines?
    By blaklabl in forum Wheels and Tires
    Last Post: 05-22-2018, 06:10 PM
  2. X01 cassette removal, lockring tool won't reach splines??
    By martinizer in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-30-2018, 05:04 AM
  3. Replies: 3
    Last Post: 10-09-2016, 11:50 AM
  4. Replies: 6
    Last Post: 02-06-2015, 08:09 AM
  5. Replies: 2
    Last Post: 07-12-2012, 04:08 PM
Members who have read this thread: 124
