Results 1 to 7 of 7
    Live 2 Ride
    Reputation: Kona0197's Avatar
    Strange bottom bracket problem...
    It seems I have a strange problem with my bottom bracket. Everytime I go out and ride my drivetrain is quiet until I put torque on the pedals. Then everytime when either pedal is in the down (closest to the ground position) I hear a creak - sounds like a loud pop. It only happens on each petal when they are on the down posistion and only when I stand on the petals or put a lot of torque on the drivetrain. I checked my crank bolts and they are snug and torqued to specs.
    Ideas?
    By the way I am using a Truvative X-Forge crank that uses a square-taper BB interface. Would regreaseing anything help and if so where would I apply the grease?
    My Bike: '15 Trek FX 7.2
    My Blog: http://http://kona0197.wordpress.com/
    Old man on a bike
    You might need to take your bottom bracket out, clean up the interfaces and regrease and reassemble (be sure to torque to spec); even if you're not getting play it could still have some grit that worked it's way in or you might have worked the cups loose a bit, which can cause noise. Your pedals can cause a noise like that too, as can a variety of things.
    Did you actually take the crank arms off or just tighten them some more? Just tightening them more will cause more problems with deformation than if you take them off then retighten them to spec (and I'd take them off and clean 'em while I'm at it); some say to use grease on the tapers, some don't (I don't and I still use square tapers too).
    suum quique
    Live 2 Ride
    Update: I pulled the bottom bracket tonight. It was made by a company called Power Pro Componets. I don't think it was torqued down properly because both sides of the bracket came lose very quickly and without much effort.
    So when I go to put it back in should I use tape? If so what kind? And should I use grease?
    Reputation: logbiter's Avatar
    I prefer teflon tape & anti sieze, but tape w/ grease works fine and torque it properly.
    Always use grease or anti sieze and be sure to clean up the threads on the BB cups & in the BB shell.
    Quote Originally Posted by Kona0197
    Live 2 Ride
    Well I put the bottom bracket back in and torqued it down proper but I still hear the creaks. of course they are a LOT quieter but I still can here them. I guess I need a new BB. Anyone have a slightly used spare 68mm square taper lying around?
    Old man on a bike
    There's still some square taper bb's available, UN-73's usually the best you can get unless you want an odd size...try qbike.com or bestwebbuys.com for a few choices.
    suum quique
    Reputation: wickerman1's Avatar
    try these things first...
    did you grease your cranks before putting them back on the BB? I know that I had to and it stopped the creaks... some dont but it solved my creaking problem... until another one came up... take your pedals off and grease the spindles too cleam them first obvioulsy... .they can cause serious creaking issues.
  1. monocog bottom bracket question...
    By homestar in forum Singlespeed
    Last Post: 11-15-2005, 08:59 PM
  2. strange noies from bottom bracket
    By simoriah in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-10-2005, 07:52 PM
  3. which bottom bracket size?
    By Jaker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-04-2005, 11:04 AM
  4. bottom bracket type??
    By Styles in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-06-2004, 10:06 AM
  5. @#$%^&* Shimano bottom bracket mounted derailler
    By old_dude in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-02-2004, 10:04 AM
