Results 1 to 13 of 13
    Aug 2005
    Straightening a bent hanger on Carbon frame
    I think I may have a bent rear derailleur hanger. I have access to the park tool straightener but before I try to straighten it, I wanted to check if its ok to put those forces on a carbon frame?
    Frame is a 2009 trek top fuel 9.8. The chain stays are aluminum, seat stays are carbon, joined together at the rear axle. (trek ABP pivot)
    I have a new extra hanger I could put on, and the $40 for another one won't kill me, but obviously I'd rather fix it if it's something that's safe to do on this frame.
    Sent from my LG-H820 using Tapatalk
    Just because you have the tool....doesn't mean you know how to use it.
    And seeing how you are asking....and state that you "think " you bent the hanger (you either did or didn't and it's pretty easy to tell)....
    Either take it to a good mechanic who knows how to straighten it....or put on the replacement (and make sure that is straight as you can tweak the mounting area)
    Aug 2005
    Quote Originally Posted by the mayor View Post
    1. I've used the tool successfully before on aluminum frames. My question is clearly specific to frame material, which your answer didn't address.
    2. The reason I "think" its bent is only because I have not yet had the opportunity to use the tool to confirm. Seeing as how the same tool is used to diagnose and fix the problem, I decided to ask my question (again, specific to frame material) before beginning the process.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Replace the hanger outright, for carbon frames. On Alu its perfectly acceptable to straighten them out, using the tool. Carbon... nope.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Aug 2005
    Quote Originally Posted by Cayenne_Pepa View Post
    Thanks. I've seen conflicting info on this. Better safe than sorry.
    You will not damage a carbon frame straightening a hanger so long as you hold the wheel and not the frame when levering the straightening tool. The thru axle traps the hanger between the endcap on the hub and the insert in the frame causing the torque from the straightening tool to be transferred to the wheel and not the frame when levering the hanger. Just donít hold the frame while straightening and you wonít have a problem. I have never had an issue in over five years straightening hangers on carbon frames.
    If your chainstay is aluminum....you aren't really dealing with the carbon part of the frame, are you?
    Aug 2005
    Not directly, but the way the seatstay is joined with the chainstay is what gives me a reason to pause. Here is a pic of the non drive side where the chain stay and seat stay meet.
    since 4/10/2009
    Reputation: Harold's Avatar
    There is some carbon there. The Trek ABP is basically a tweak on the Split Pivot design, which I have on my Bucksaw. I have carbon seatstays and alu chainstays on my bike, too. I have had mechanics tweak my hanger back more than once. One of those times, it was a Salsa rep who did the straightening. I would figure if straightening the hanger would be cause for concern on that frame, he would have refused.
    For those not familiar with this sort of rear suspension design, it's probably a bit different than some others WRT how the forces are distributed on the hanger. The rear axle threads into the hanger, which sits between the parts of the frame that also attach there and the rear hub. A nut preloads the rear suspension bearings and holds the stays together from the exterior. The ABP is a little different, but a very similar application.
    Judge Rules Trek's ABP Design Does Not Infringe on DW's Split Pivot Patent - Mountain Bikes News Stories - Vital MTB
    I doubt that straightening the hanger with the DAG tool puts much stress on any element of the frame at all.
    Straightening a bent hanger on Carbon frame-trek-remedy-9-27.5-studio-29-710x473.jpg
    If you hold onto the portion of the wheel next to the end of the straightening tool when levering the tool all the forces are transferred from the hanger ---> axle ---> wheel. As long as you don't grab the frame while levering the straightening tool no force is applied to the frame.
    How so? So when you put that new hanger that isn't straight on what do you do? new hangers aren't always straight.
    If the frame is strong enough to handle the crash/hit that bends the RD hanger, why isn't it strong enough to handle the same forces using a tool?
    OG Ripley v2
    Carver 420 TI
    Quote Originally Posted by TwoTone View Post
    Agreed. You have nothing to worry about. Just use the Park tool as you would on an aluminum frame. The carbon frame is likely stronger than it's aluminum counterpart would be.
    fuggansonofahowa
    Reputation: Hawseman's Avatar
    Quote Originally Posted by BlownCivic View Post
    Damn, I'm glad you said that. If the hanger is stronger than the frame, there are some fundamental design flaws in carbon mountain bikes......and a lot of people got ripped off (including me).
  1. Straightening a crooked seat tube
    By evanrlew in forum Frame Building
    Last Post: 06-01-2016, 04:10 PM
  2. Straightening Rotors - Do I push or pull?
    By BobaX in forum Brake Time
    Last Post: 09-24-2013, 06:56 PM
  3. Straightening rim dints - advice please
    By StevieC in forum All Mountain
    Last Post: 11-06-2011, 04:00 PM
  4. Straightening a wheel? 56k beware.
    By 96firephoenix in forum Wheels and Tires
    Last Post: 08-31-2011, 09:16 AM
  5. Straightening handlebars
    By Razorhog in forum Beginner's Corner
    Last Post: 05-24-2011, 12:16 PM
