    Apr 2005
    Sticky shifter help
    I have XTR thumb shifters, & on the front derailiur shifter, when I shift up to a larger ring, the large(thumb) shifter is sluggish returning to it's position. Cables look good, so I assume it's internal to the shifter itself. Is there a way to service or clean these(that isn't rocket science)?
    Vance in AK.
    MTB B'dos
    Reputation: LyNx's Avatar
    Quote Originally Posted by Vance in AK.
    My rear Deore shifter was sticking when I used the multiple gear shift down(click, click, click), I just undid the bottom cover and sprayed some lube in there and it is working fine now. NOt sure if the XTR is the same setup.
    Old man on a bike
    Searches can do wonders....and it doesn't sound like you have thumb shifters, you probably have rapidfires... Shimano shifter pod issue
    suum quique
    Apr 2005
    Thanks guys. That's what I needed.
    And yes, they are rapidfires, I just inapproiately used the label thumb shifters as opposed to twist type. My mistake.
    Vance in AK.
  1. Using a rear gripshift shifter on a front deraileur
    By mango in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-27-2005, 02:51 PM
  2. using shimano xtr 2003 rear derail. with deore mega-9 shifter
    By m4dj4ck in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-17-2004, 02:31 AM
  3. shifter & deraileur compatibility?
    By iLUVmySH in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-30-2004, 05:43 PM
  4. Problem with XT rapidfire rear shifter
    By dbreda in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-02-2004, 12:36 PM
  5. 04 SJ - shifter cables along downtube?
    By Phil in forum Specialized
    Last Post: 02-15-2004, 07:10 PM
