Results 1 to 2 of 2
Thread: Sticky shifter
    Sticky shifter
    SRAM XO 9 speed front triple shifter.
    When I shift from the smallest to middle chain ring the thumb shifter get stuck forward and does not return. I can easily manually pull it back with my finger. It doesn't seem to be bad cable pull because it still downshifts nice and crisp. Also when shifting from the middle to big ring, it returns just fine, it is only the small to mid-ring shift where it sticks.
    Any ideas?
    Reputation: KevinGT's Avatar
    Dec 2012
    Could it be a cable kink and housing transition that only manifests when the cable is in the middle ring position?
    Considering the cable is obviously 100% positional (versus hydraulics, which are not positional at all), I'd think it's something that occurs when two things are lined up. In other words, maybe the kink is right where the cable leaves or enters a housing and it only affects things at that specific point.
  1. Xloc is Sticky
    By Alexgonzalezmi in forum Shocks and Suspension
    Last Post: 02-28-2014, 03:17 AM
  2. Sticky X9 rear shifter help
    By jeffgre_6163 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-21-2013, 12:56 AM
  3. Brakes are not as sticky
    By DJ/UF in forum Brake Time
    Last Post: 08-11-2012, 01:04 PM
  4. Tire for sticky mud?
    By Warp in forum Wheels and Tires
    Last Post: 07-28-2011, 11:38 AM
  5. Tyres for sticky mud?
    By PeteStew in forum Wheels and Tires
    Last Post: 01-31-2011, 02:22 PM
