sram xx dearliuers with sram xo grip shift
can i use an sram xx rear and front deraliuer with sram xo grip shift if thy are both 2x10?
The SRAM site shows that all of their 10 speed MTB derailleurs and shifters are compatible with each other - within 2X10 and 3X10.
the answer is yes. you can even use roadie levers if you want, sram 10 speed stuff is all the same.
I thought road has different cable pull per shift?
- You may not post replies
- You may not edit your posts
Forum Rules
