Results 1 to 7 of 7
    Nov 2007
    Sram X9 Missing Anchor Bolt Problem
    I got a problem with my rear derailleur - SRAM X9 medium cage. Manual shows a derailleur with the anchor bolt in it's very obvious spot (red circle below) while mine is like the 2nd picture ... WTF sram? did anybody have that issue before ?
    Attached Thumbnails Attached Thumbnails Sram X9 Missing Anchor Bolt Problem-sram-x9-bolt.jpg
    It just looks like they moved the anchor position from the bottom to the top of the cage. The anchor bolt should be on the same side as that plastic cable guide right?
    Nov 2007
    Quote Originally Posted by smilinsteve View Post
    It just looks like the moved the anchor position from the bottom to the top of the cage. The anchor bolt should be on the same side as that plastic cable guide right?
    I will take a photo tonight ... but no, there is no bolt (at least a obvious looking one) on the inside where the cable would fasten to
    Look at this document: It looks like your routing should be similar to the XX/XO derailleur routing diagram. (I think your anchor bolt is on the top of your cage, but the head of the bolt is facing down, ie, inside the cage rather on top).
    http://www.sram.com/sites/default/fi...ailleurs_4.pdf
    Isn't this it?
    Attached Thumbnails Attached Thumbnails Sram X9 Missing Anchor Bolt Problem-sram-x9-1.jpg
    Nov 2007
    Isn't this it?
    good stuff ... will try tonight, thanks alot!
    Never trust a fart
    Reputation: frdfandc's Avatar
    smilingsteve is correct. The X9 RD had a cable anchor location change 2 years ago IIRC.
  1. HELP - Sram X9 rear derailleur stripped anchor bolt
    By JOwens14 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-23-2011, 06:54 AM
  2. SRAM HammerSchmidt 'Boat Anchor'
    By Flappy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-01-2008, 03:10 PM
  3. Stripped derailleur anchor bolt - Deore XT
    By jaybay in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-17-2008, 08:52 PM
  4. BB7 Anchor Bolt and Bolt?
    By Musichead13 in forum Brake Time
    Last Post: 06-12-2007, 05:01 AM
  5. Replies: 2
    Last Post: 11-11-2005, 11:04 PM
