Results 1 to 2 of 2
    Jun 2013
    SRAM X9 Derailleur chain jumping off bottom pulley help me
    Hello all,
    I have a SRAM X9 rear derailleur and the chain jumps off the lowest pulley. It started doing it consistently about 2 weeks ago. There is no real rhyme nor reason for it to happen. Sometimes I can just be coasting or sometime when I am going over log piles or really rooted area. Can the pulley wear out? Can it be replaced? Or just an adjustment? Thanks for your help.
    a
    Never trust a fart
    Reputation: frdfandc's Avatar
    Pulley can wear out. Life expectancy depends on conditions the bike is ridden.
    But since it's during coasting or bumpy areas like a long root section, the spring for the cage might be worn, depending on age.
    If this is worn, you might be able to pick up a cage/spring kit instead of a complete derailleur.
  1. sram x0 crank and x7 derailleur compatibility with shimano triggers and chain
    By stmarti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-06-2014, 02:17 AM
  2. Replies: 19
    Last Post: 10-24-2013, 12:39 PM
  3. Chain falling off dérailleur pulley
    By vitale232 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-19-2012, 01:09 PM
  4. Derailleur pulley help needed
    By zarr in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-21-2011, 08:29 PM
  5. What pulley for RD950 XTR derailleur?
    By GTscoob in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-23-2011, 08:54 AM
