Results 1 to 5 of 5
    Reputation: CADEXX's Avatar
    New question here. Are Sram X7 shifters compatible with a XT 9 speed rear derailleur?
    I am having problems with getting the index right with the shifting. Every time I up shift one, the rear derailleur moves 3 up the gears! Are Sram X7 shifters compatible with a XT 9 speed rear derailleur?
    SuperInstigator
    Reputation: tibug's Avatar
    Nope. Sram X series and Shimano don't intermix with good results...
    Tim
    I wish I didn't know now what I didn't know then.
    ...idios...
    Reputation: SteveUK's Avatar
    SRAM is 1:1 actuation, Shimano is 1:2. So, with SRAM, when you pull 1mm of cable, the derailleur will move 1mm. With Shimano, when the cable is pulled 1mm, the derailleur will move 2mm, hence your jump in gears.
    Diogenes
    Former Bike Wrench
    Get yourself an X.9 rear derailluer and witness drastically improved shifting (even over a XT shifter with an XT rear derailluer).
    BTW-the front (left) shifter is compatible with Shimano or SRAM front derailluers. Its just the rear shifter/derailluer combo that Shimano and SRAM do not play nice together.
    Auto-x addict
    Reputation: VpointVick's Avatar
    Or get yourself a set of SRAM Rocket shiifters to work with your XT der.
    I'd recommend what he said ^^^ though.
