Results 1 to 7 of 7
Thread: Sram X.7
    "El Whatever"
    Reputation: Warp's Avatar
    Sram X.7
    How good is this drivetrain at full (exception of the crank and FD, I know)???
    To which Shitmano group can it be compared???
    THX!!!
    Check my Site
    Get your freak on!
    It's Sram!
    The X7 is probably aimed to compete with LX(in price) but it is probably closer to XT when it comes to performance.
    Between LX and XT I would say it sits
    "El Whatever"
    Quote Originally Posted by bike_freak
    It's Sram!
    Next drivetrain I will have... any issues to be known???
    Check my Site
    Quote Originally Posted by Warp2003
    The gear indicators seem to be a bit dodgy, and I've got problems with ocassionaly skipping gears under load. Got a tune up and all was well... but riding home last night, I had problems with it skipping up and down a rear cog. Not sure how related to X7 it is yet, as I just found a tight link on the chain, so maybe that was causing problems. Aside from this, it feels really nice though, and shifting is far far slicker than the Deore junk I had on previously.
    willtsmith_nwi
    Reputation: willtsmith_nwi's Avatar
    Jan 1970
    Better than Shimano ..
    THX!!!
    I just installed an x.7 shifter/derailleur/brake lever set. It's a LOT better than the Shimano stuff, but I wish I'd gotten the x.9 with it's pully system and straighter cable line.
    Thinking of chaging to a set of X7 too.
    Wonder if anyone using the X7 system with Shimano XT cassette and raceface Crankset? Which chain should I go for?
    thanks...
    Get your freak on!
    Quote Originally Posted by opticals
    thanks...
    You will be 100% fine with your raceface crank and shimano cassette.
    As for chains. I like Sram chains, but you could also get a wipperman.
    Just I don't like shimano chains as they don't have the 'quick link'.
    And depending on how many miles you have done. You may want to replace your cassette and chainrings if getting a new chain. Then it will all run alot smoother.
    If your chain is too far worn, then your cassette and chainrings are also going to be worn.
  1. Front Derailer issue.....SRAM X.7
    By montgod in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-29-2004, 07:33 PM
  2. SRAM X.7 Setup?
    By Ohio Mike in forum General Discussion
    Last Post: 08-11-2004, 10:57 PM
  3. Thinking of upgrading to SRAM X.7 Shifters...
    By some_guy282 in forum Beginner's Corner
    Last Post: 08-06-2004, 09:01 PM
  4. SRAM X.9 Triggers vs X.7 Triggers
    By cycljunkie in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-10-2004, 12:29 PM
  5. SRAM X.7 compared to X.9 and X.0
    By XC_Miles in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-05-2004, 06:10 PM
