Results 1 to 3 of 3
    Apr 2013
    Sram X.0 crankset - outer bolt damaged
    Hi,
    I need some advice from you guys.
    On Friday I removed the crankset from the bike. I didn't read the instructions properly and before successfully removing the cranks with the inner self extracting bolt (8mm) I tried to remove the outer one (10mm). The problem is that the manufacturer of the bike (Canyon) or Sram must have used blue loctite to lock it in. And I basically badly rounded the outer bolt trying to get it out. Impossible.
    The self extracting system still works like a charm, but I'm wondering what I shall do.
    What do you guys suggest? Is there any reason at all why I may need to remove the outer bolt in the future? Or can I just leave it as it is and not worry about it at all?
    Thanks for your precious advice
    Regards
    Marco
    Well...barring unforeseen circumstances, you'll never need to remove the self-extractor cover.
    However, if it really bothers you (or becomes an issue, for whatever reason) you should be able to remove it either with a very large easy-out type extractor (which would be rather large, and would need to fit exceedingly well) or attempt cutting/grinding it out with a rotary tool. You would then need to find a replacement for it, and to be honest, it probably isn't worth the time and effort unless the fixing bolt shears/strips.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    Quote Originally Posted by wschruba View Post
    what he said
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
  1. Replies: 122
    Last Post: 04-16-2014, 05:02 PM
  2. Shimano M665 SLX 2x9 crankset - can I run it with a 32t middle and 44 outer?
    By Earthpig in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-30-2013, 10:32 AM
  3. X9 Rear Derailleur Hanger bolt outer washer question w/ Pic
    By F2a in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-30-2012, 10:21 AM
  4. XO crankset smallest outer chainring?
    By Quinner in forum General Discussion
    Last Post: 02-07-2012, 09:37 AM
  5. I'm an idiot - crankset bolt issue. Help!!!
    By MoreCowbell82 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-10-2011, 09:18 PM
