Results 1 to 14 of 14
    Sram and Shimano 10 speed compatibility?
    Making the jump to 10 speed, so far I have ordered Sram XX shifters, front and rear derailleurs and crankset. Can I use Shimano cassettes and chains like I could with my ex 9 speed setups? Not as concerned with the chain as I am with the cassettes as the XT cassette looks like the way to go, the XX is fragile looking and crazy expensive and the 1070 does not appear to be on par with the XT unit. Anyone mixing it up yet?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Anthem1
    Should work
    mtbtires.com
    no worries...
    O.K. got a deal on a XT cassette and chain combo on ebay as well as a Sram 1091R chain. I will due some back to back tests on shifting and noise and post my thoughts once I get this puppy put together.
    Reputation: nathanbal's Avatar
    has anyone actually tried this? my LBS tried it and they said the spacing was slightly different and shifting was off.
    Former Bike Wrench
    The cassette spacing is the same, but there are some variations in the chains.
    RHRF!
    Reputation: titusbro's Avatar
    Works for me...
    I'm running an XT 10sp cassette w/Sram 1051 10sp chain, X.9 RD/Shifter, XTR FD, 32/22 rings - works great!
    "The secret of joy is the mastery of pain." (Anaïs Nin)
    I am glad it works for you but it is not supposed to be an ideal fit. The 10spd XT cassette is intended to be matched with the XT chain. The teeth on the cassette are thicker and not matched to the Sram chain.
    Anthem1
    Any updates on the XX shifter and XT cassette and chain combo? I'm really interested in this since SRAM doesn't have a 11-36 10speed cassette except the XX.
    Reputation: deanmachine's Avatar
    Feb 2006
    Quote Originally Posted by john85D
    Anthem1
    .They have a 1090, 1070 and 1050 ten speed cassette in 12-36.
    MDJ
    MDJ is offline
    Jan 2005
    Specialized specs Sram shifters/deraileurs, with Shimano cassettes and KMC chains on several of thier bikes.
    Quote Originally Posted by deanmachine
    I prefer to have a 11t cog since I use my bike for DH as well, I need the higher gear. I wonder why SRAM doesn't give us more options with this gearing.
    Bicyclochondriac.
    Anthem1
    Yeah, SRAM really crapped the bed on this one.
