Results 1 to 6 of 6
    Oct 2012
    sram rocket shifters and shimano components
    Ok Im new to building mountain bikes but im giving it a try..
    I bought a set of monkey lite bars, scram rocket grip shifters and avid juicy 3 levers and calipers and lines.
    These are used items but nice non the less.
    My question is the rocket shifters are a 3 x 9 set up, my shimano xt crank is a 3 chainring design and I dont have the rear cassette yet.
    Will the rocket shifters work with the 3 chainring fine AND the cassette for the rear could or should I buy a 9 or will a 10 work, I already have a xt 10 cassette.
    Thanks guys in advance.
    The rocket shifters should work fine with your front derailleur and crank.
    Rocket shifters are designed to work with a Shimano rear derailleur. You need to match the number of gears of the cassette with the number of gears on the shifter - from the sounds of it, a 9 speed. A Shimano or SRAM cassette will work.
    Oct 2012
    Thanks, my front 3 ring is a 44, 34, 22 does that make a difference?
    dru
    dru is offline
    Slash is talking about cage length on the rear derailleur. They come in two or three lengths. You will want the 'long cage' version because you are using 3 rings up front.
    Drew
    occasional cyclist
    Oct 2012
    Ok dru thanks, does the chainrings I listed sound like they were a 3x10 or 3x9?
    OR does that even matter and no matter what the chainrings are they will work
    With the 9 speed cassette and long cage deraillure ?
    Thanks again, sure helps me a lot..
    dru
    dru is offline
    I know nothing of the 10 sp. stuff except that the rings are (suppossedly) skinner than 9. Being you are running 9 speed shifters and cassette your rings on the crank will work just fine.
    Drew
    occasional cyclist
