Results 1 to 9 of 9
    Reputation: Tiffster's Avatar
    Sram Red front mech
    Hi all,
    As i only use a 2x9 setup with 32,44 chainrings would it be possible for me to fit a sram red front mech to my bike instead of my XTR one?
    Im using XO triggers if it makes any difference....
    it's....
    Reputation: Strafer's Avatar
    Yes you can.
    Front derailleurs are not brand specific.
    In exile
    Reputation: loco-gringo's Avatar
    While not brand specific, Sram fronts don't work "well" with Shimano STI. A Red might work, but I'll bet it's not well.
    it's....
    Quote Originally Posted by loco-gringo
    Huh? OP is using XO SRAM shifter, not STI.
    Hi sorry,
    My post wasnt clear. What i meant was could i use a Red front mech on a mtb with mtb chainrings and spacings etc as it's different from road....
    Reputation: FrankinMich's Avatar
    Dec 2005
    Some things to consider.....
    Quote Originally Posted by Tiffster
    Hi sorry,
    Road front derailleurs usually have a longer cage than MTB shifters in order to work better with the large chain ring on road cranks (typically 50-54T). Depending upon your frame design, it could be an issue. Also, the SRAM Red is designed to work optimally with a 10 speed chain, so the cage width may be slightly narrower than your current front derailleur. This could be a potential issue in some gear combinations.
    As far as I know, the spacing between chain rings on a road crank and MTB crank are the same. However, I am not familiar with road double cranksets so you may want to measure the spacing on both cranks -- just to make sure.
    Reputation: RiderInTraining's Avatar
    Apr 2005
    Quote Originally Posted by FrankinMich
    ... As far as I know, the spacing between chain rings on a road crank and MTB crank are the same. However, I am not familiar with road double cranksets so you may want to measure the spacing on both cranks -- just to make sure.
    Wouldn't matter anyway, since it's the shifter that determines how far the derailleur swings when you shift not the derailleur itself.
    I'm Confused . . . Wait a Minute, No I'm Not . . .
    Old thread this - update. Ive been running a Red front mech for months now, converted it myself no problems
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by RiderInTraining
    Not quite. Both the shifter and the derailleur determine how far the cage moves. At least with Shimano RDs the road and mtb models use different amounts of cable pull for the same amount of cage movement.
    mtbtires.com
