Results 1 to 9 of 9
    Reputation: dochou's Avatar
    New question here. SRAM powerlink is stuck, Help.
    Hi I put on a SRAM Powerlink on my 10 speed chain. It is the one for 10 speed chains. I can not get it to slide off now. It does not slide off. Any tips on how to get it to slide apart. When I placed it on, there was alot of resistance too. Thanks
    Plays with tools
    Reputation: customfab's Avatar
    The 10spd links are way tighter than your use to with Sram 8/9 links. You need a pair of pliers to remove them. Park makes a special set that work really well. You can also use modify a set of needle nose to work as well. The 10spd Sram links are also not supposed to be reused. People do it and seem to think it's OK, but Sram says they are disposable.
    http://www.abbeybiketools.com/
    --- industry disclaimer ---
    usually cranky
    Reputation: b-kul's Avatar
    aside from some chain voodoo once they are on they are on.
    To tack on to what customfab said: If you're nervous about the 'do not reuse' part, throw a KMC master link on, as they are reusable, according to KMC (but only if removed with master link pliers).
    Sep 2004
    The Sram 10 speed link is designed to be single use only. You can reuse them but it would be easier to buy a KMC masterlink, it is reuseable and I have had zero problems.
    new name, old member
    Reputation: Bike Whisperer's Avatar
    They call the 10 speed link Powerlock for a reason
    Single and loving it (single speed bike that is)
    http://mtnbiker72.blogspot.com/
    http://www.ccfa.org/
    Dunno if it was a good idea, but I filed my SRAM Powerlink to make it easier to put on and take off. Only had a few rides with it, but so far it works just fine.
    Plays with tools
    Quote Originally Posted by belljeffw View Post
    Hopefully when your nuts smash into your stem they don't burst.
    Sep 2004
    @customfab,
    That is very true and very funny.
Hot Deals
Contests
Latest Mountain Bike Articles
