Results 1 to 6 of 6
    Arrrghhh!!!
    Reputation: insighter's Avatar
    Nov 2006
    SRAM PG970 12-26 for mtn bike
    Did a search on previous threads and couldn't find an answer.
    I've got a 9 speed XTR der with an LX cassette and am looking to lighten it up, and don't use the two biggest cogs.
    How would a 9-speed SRAM road cassette work with a 9speed Shimano mountain bike setup?
    Is this a stupid idea?
    Thanks in advance,
    Reputation: flipnidaho's Avatar
    should work ok... you may have to remove a few links off your chain (and hope that the chain is not too stretched if you're using a new SRAM cassette). FWIW, I run a SRAM r. derailleur with an XTR cassette.
    It'll work fine. I've run an Ultegra 12-27 with an XO rear derailleur. I believe the Ultegras are lighter, if you don't have the SRAM yet. I ended up going back to the 11-34 XT because I liked the noticable shift between gears. The road derailleur was too tightly spaced for my local trails and I ended up double shfting most of the time. It might be good on the right trail. Also, I missed the 11 tooth cog on the road ride to the trails, as I was spinning out in the 44 x 12 combo at times.
    Arrrghhh!!!
    Nov 2006
    Thanks for the info-- good points, and I'll think further about upgrading. I didn't consider the differences between gears and how that would effect shifting. Y'know, I think I might have been better served with less gears...
    Reputation: FireDog46's Avatar
    a couple of other options
    First: if you're changing just to drop a bit of weight you aren't going to gain much, unless
    you are willing to spend a lot of money. However, if you are looking for different gear ratios
    you should check out Harris Cyclery http://sheldonbrown.com/harris/k7.html and scan
    down to the custom cassettes they offer. I am using the "CS914 Century 12" which has
    "12 13 15 17 19 21 24 27 30" spread and translates into a medium range with the ratios
    fairly evenly distributed. When I got it I was pleasantly surprised to find they had taken
    and Ultegra 12-27, removed the 14 and added a descrete 30. The best overall cassette
    group for MTB'ing was the XT 12-34, which is no longer available but can be had in the XTR
    line for a hefty price and will not last as long as the old XT version. The 12-34 is wide range
    and again the ratios are fairly evenly distributed.
    Poke around Harris Cyclery. There are a number of interesting options for cassettes
    that wont cost you an arm and a leg.
    michael
    "Be not afraid of going slowly but only of standing still." - Chinese Proverb
    Arrrghhh!!!
    Nov 2006
    Thanks for the info
    Thanks for the info from Harris-- I'll check it out.
  1. SRAM PG970 -vs- Shimano XT M960 Cassette
    By KPVSR in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-04-2007, 04:41 AM
  2. SRAM is going to make bike frames? Here's the concept bike, HAWT!
    By Robot Chicken in forum General Discussion
    Last Post: 10-05-2005, 10:01 PM
  3. SRAM spec'd bike?
    By blevyibr in forum SRAM
    Last Post: 04-09-2005, 09:24 PM
  4. Problem with PG970 (xpost Drivetrain)
    By ibmkidIII in forum SRAM
    Last Post: 11-03-2004, 08:15 PM
  5. Problem with PG970
    By ibmkidIII in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-02-2004, 02:38 PM
