Results 1 to 3 of 3
    Sram PG 1070 to XG-1080 or XG-1099
    Below are some specs on my Scott Scale Drive.
    RWS QRChainSram PC 1051 Cassette Sram PG 1070, 11-36
    Rear Derailleur Sram X0 carbon long cage, 20 Speed
    Crankset Sram Carbon S-2210 GXP PF, Carbon crankarm 38Ax24A
    I am fairly certain an XG-1080 can replace the 1070 with no problems, but can the XG-1099 be put on this bike with its current other sram parts and be a simple conversion?
    Or are the problems or things to be aware of ?
    davidcarson48
    Guest
    Re: Sram PG 1070 to XG-1080 or XG-1099
    Both are completely compatible. No issues.
    THanks I wasn't sure because of the Power dome difference in the teeth and if that meant a specific Chain type was needed that could not be diff. from the Crank teeth shape.
