Results 1 to 8 of 8
    SRAM PF30 BB - Incredible amount of drag
    Anyone else found that this BB has an unreasonable amount of drag? I've triple-checked the bearing tension and even with the collar backed all the way off, the bearings are really stiff. Feels like they're packed with molasses. Will it loosen up with time? Are there reasonably priced alternatives that are better?
    This is on a Jet9 RDO that I took a lot of care to build up light for racing, and I can't help feeling that this BB is robbing a lot of power.
    Oct 2010
    I have the same feeling on my Stumpjumper with PF30 and S-Works crankset. I think it all seal drag in my case, because I have sprayed a thin lube the seal its much better. I hope someone has found a fix or a BB that works better. If not, Chris King is shipping their PF30 BB in the very near future.
    arrogant sandbagger
    May 2010
    Have you ridden it yet?
    I have no experience with PF30 but my GXP BBs would not even complete a rotation in the stand when I spun them. They all loosened up within a ride. In fact, I remember seeing a video explaining sram BB/crank installation which said exactly that.
    Oct 2010
    I have several hours on mine, they did not loosen up. The PF30 is very different set up compared to GXP and that being said my actual BB is the Specialized brand which is different (slightly) than the Sram.
    I've only got a couple hours on it, so I guess I'll keep riding it for a while. Was curious if other people found they loosened up over time.
    thecentralscrutinizer
    Reputation: mopartodd's Avatar
    I don't notice it when riding which makes me beleive it's just the seals.
    2015 Kona JTS
    2014 Scott Scale 710
    2014 Giant Anthem 27.5
    Dec 2009
    Quote Originally Posted by spsoon View Post
    Same here. I just installed the SRAM PF30 on my steel frame cross bike. There is a huge amount of drag. It seems to be beyond reasonable for seal drag. I only have about three hours on the BB from a ride yesterday.
    The WW forum has posts about mis-alignment of the bearing cups and someone else talked about polishing the spindle to get it to insert more freely.
    I checked my set up and the bearings are smooth.
    To update the thread, I've got maybe 30 hours on mine now and it has loosened up considerably. A good flick of the wrist will now spin it about 3-4 revolutions with the chain off. I think the grease the bearings come packed with just needs to be loosened up with some use.
  1. SRAM PF30 to English Adaptor
    By PlanB in forum Niner Bikes
    Last Post: 05-21-2015, 09:14 AM
  2. SRAM PF30 BB installation
    By kwarwick in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-08-2013, 06:16 AM
  3. avid sram xx brake drag w non oem pads
    By pointless debate in forum Brake Time
    Last Post: 05-17-2012, 06:13 PM
  4. Experience with SRAM PF30 to GXP adapter?
    By mtroy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-23-2012, 10:27 AM
  5. SRAM PF30 to BSA adaptor
    By PlanB in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-11-2011, 07:05 PM
