Results 1 to 10 of 10
    cavediver
    Aug 2005
    SRAM/low normal?
    Are Sram rear derailers low normal, or high normal?
    Formerly DMR For Life
    Reputation: Full Mountain's Avatar
    Mar 2005
    low...only shimano makes high normal stuff
    DMR
    born again
    Reputation: gearz's Avatar
    Sram = High normal
    Quote Originally Posted by sloepoke
    Only Shimano makes rapid rise (low normal) derailleurs. I believe DMR has it backwards. I run xtr rapid rise and like it.
    Classic Cascade Rides
    Original quote by Pinchflat:
    The faster you go the shorter the ride!
    Chrome Toaster
    Reputation: Hecubus's Avatar
    SRAM is high normal. Low Normal=Rapid Rise
    Nothing here
    Reputation: Unknownrash's Avatar
    Sep 2004
    How about SRAM=Just normal and Shimano=Bass Ackwards. I never understood the High vs. Low normal bidness. Shimano should stop the madness.
    Chrome Toaster
    Quote Originally Posted by Unknownrash
    You should go weigh in on the front brake on the right or left lever thread. There is nothing like a good argument on which way on something that is completely preference based is right or wrong.
    Mar 2005
    that doesn't make sense to me because the spring brings the der. to the lowest gear while i have to pull the cable to get it to the higher gear that makes it low normal to me...what am i missing here
    DMR
    EDIT : See LyNx's post in "newbie derailuer replacement"
    Reputation: lebikerboy's Avatar
    Jan 2005
    Low normal aka Rapidrise means when there is no tension on the rear derailleur, the chain will be sitting on the largest rear cog or, lowest gear.
    QUOTE=DMR For Life]that doesn't make sense to me because the spring brings the der. to the lowest gear while i have to pull the cable to get it to the higher gear that makes it low normal to me...what am i missing here
    DMR
    EDIT : See LyNx's post in "newbie derailuer replacement"[/QUOTE]
    Chrome Toaster
    Quote Originally Posted by DMR For Life
    DMR
    The big cogs in the rear drive are the low gears. A low normal means the derailleur normally rests on the biggest(low) cog unless there is cable tension.
    cavediver
    Aug 2005
    thanks
    Thanks that answers my question. One of my bikes is low normal, and the other is high normal. i like the low normal best, it seems to work better for me, and I am going to replace my rear derailer so both bikes will be low normal.
