Results 1 to 6 of 6
    Reputation: codyg's Avatar
    Feb 2010
    SRAM GXP Crank Removal
    I'm probably over looking something simple, however, I thought I would post here before I broke something.
    How do I remove the crank on a SRAM GXP? I took the large nut out (10mm hex), what's next? Youtube videos make it look like it should either fall off after that or you need the removal tool. Am i just missing something simple or do I need the tool?
    Picture attached.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    ya.. you leave the large nut in... LOL
    there is a nut that is more of a thick, threaded washer that is cupped on the inside, that goes over the actual mounting bolt. as the mounting bolt is backed out it pushes on the outer nut/washer thingy and pushes the crank arm off. neither one ever actually gets taken off the crank arm...(thou I take them off to clean now and then)
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Yeah, you're looking at the wrong side.
    Go in from the drive side (side with the chainrings) and use an 8mm hex wrench counter clockwise. Once you get the crank out make sure you don't lose the little dust cover that fits onto the bottom bracket because it will likely fall off as you're removing the crank.
    Feb 2010
    Here is a pic of the otherside, you can see all the way through.
    Quote Originally Posted by dragonsnack View Post
    That's what is known as a 'self-extracting' crankarm bolt. You removed the extractor.
    Put the whole shabang back together, and thread the 10mm nut/washer on until it is completely engaged with the crank arm's threads. It should not be binding the bolt, which should be able to turn freely. Use an 8mm hex key through the nut/washer and turn the bolt inside counter clockwise. It will push against the nut, pushing the arm off of the spindle.
    Bicyclochondriac.
    No, he's looking at the correct side.
  1. SRAM X7 Crank arm removal
    By ElDuderino2412 in forum 29er Components
    Last Post: 02-16-2013, 08:22 PM
  2. Sram xx crank removal
    By cabbgage in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-20-2012, 10:09 AM
  3. SRAM X9 gxp crank removal
    By kpr3186 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-09-2012, 04:04 PM
  4. crank/bb removal trek 3700 - sr suntour crank
    By Jason B in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-27-2012, 12:03 PM
  5. crank arm removal
    By RichardCurtis in forum General Discussion
    Last Post: 03-14-2011, 09:15 PM
