Results 1 to 2 of 2
Thread: SRAM GX issue
    SRAM GX issue
    Howdy! Anybody have issues with their GX derailleur? Mine tends to toss the chain off into the spokes from the 42 tooth cog...shifting up to the cog is fine, but if I do a sustained steep climb, the chain seems to invariably pop up and over into the spokes while pedaling forward. I tried adjusting the set screw for the low gear end, but doesn't seem to help much.
    Also is doing the more classic dropping several gears higher with a few backpedals, but this is much less of an issue.
    Reputation: Steel Calf's Avatar
    Feb 2010
    turn the low end set screw clockwise till the derailleur won't shift up the 42cog anymore, then turn it back a little bit (1/4 increments) till it works again.
  1. Possible issue with SRAM X9 drivetrain???
    By wdellio0221 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-17-2016, 12:36 AM
  2. Sram gx clutch issue
    By Biffff in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-02-2016, 07:40 PM
  3. DT 350 - Sram 11 speed issue
    By 8iking VIIking in forum Wheels and Tires
    Last Post: 11-05-2015, 01:36 PM
  4. SRAM X7 - Low Gear Issue
    By Usulsuspct in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-19-2013, 02:11 PM
  5. Sram Chain issue
    By mtbfyrefyter in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-22-2012, 09:42 PM
