Results 1 to 3 of 3
    Jun 2013
    SRAM Derailleur Indexing
    Hello,
    I am having trouble with shift indexing on my rear derailleur.
    I have a SRAM X.0 9-speed shifter, SRAM X.5 rear derailleur, and SRAM 9-speed cassette.
    When it is adjusted to work on the low gears, it starts messing up on the high gears. If I adjust it to work on the high gears, it starts jumping on the low gears.
    According to all the retailers, the X.5 is compatible with 7, 8, and 9 speed systems, but it seems to me that the derailleur is moving too far for the sprocket spacing. The spacing is 4.8mm for 8-speed and 4.35mm for 9-speed. Is the shifter supposed to take care of the difference?
    Do I need an X.0 derailleur?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by MudSnow View Post
    Hello,
    The RD is fine.
    Check the hanger alignment.
    mtbtires.com
    Jun 2013
    I had a similar problem with my shimano set up, i spent hours trying to fiddle with cable tension only to have one side working and the other not. Im fairly new to maintaining my bike myself. I found checking the R tensioner screw did the trick for me. In case you dont know how far its supposed to be you need to get it as close to the lowest sprocket as possible without it grinding. Once that is done try setting up from scratch again.
  1. Replies: 0
    Last Post: 03-28-2013, 04:05 AM
  2. New drivetrain: Can't get the indexing right
    By 007 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-10-2013, 08:26 PM
  3. SLX Double and Bash Indexing
    By Ripley_405 in forum General Discussion
    Last Post: 10-03-2011, 04:49 PM
  4. Indexing and Freewheels
    By CS2 in forum Vintage, Retro, Classic
    Last Post: 10-03-2011, 02:57 PM
  5. SRAM Twist XO with 2x10 Shimano or SRAM front derailleur
    By epiphreddy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-21-2011, 08:52 AM
