Results 1 to 13 of 13
    Reputation: allthatflash's Avatar
    Sep 2012
    Sram chain rings don't for my XO??
    Sram chain rings don't for my XO??-20130603_222345.jpgSram chain rings don't for my XO??-20130603_222423.jpgSram chain rings don't for my XO??-20130603_224052.jpg
    Got this Chainring set with the spider in 26/39 to upgrade my 24/36 XO ones but when I swapped out the rings the spiders would not go in cuz the XO arms are fatter then the groove on the spider? The guy I bought it from said they fit all XO, X9, X7 but it was not the case here on my XO....does anyone have more info on these?
    Reputation: Nater's Avatar
    Is your X0 crankset a BB30?
    If it's a GXP model, that might explain it. This spider pictured is for a BB30 crankset.
    Or this spider is for the aluminum arms (X9, X7) but not the carbon (X0) arms. My X0 arms are much fatter than my X9 arms.
    QBP lists spiders specific to X9 or X0.
    Sep 2012
    Quote Originally Posted by Nater View Post
    My cranks are GXP not BB30...I looked into this before i purchased and nothing on Sram site that said anything about anything being incampatible in this realm....pisses me off and a waste of time on my behalf. I did find out the carbon cranks are different then the alloy ones just now.....so a BB30 XO spider with a 120 BCD will not work on my XO cranks?
    Sram chain rings don't for my XO??-p4pb9156619.jpg Like this one?
    Sep 2012
    Thanks for your info BTW Nader....
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Not to rub salt in your fresh wounds, but there are multiple choices for bike components these days, and reasons that they offer them. They list about a dozen replacement spiders on the SRAM website, very clearly delineating the BB type as an option.
    This is like putting diesel in a gasoline engine. Probably should have known before you bought it.
    Death from Below.
    Sep 2012
    Quote Originally Posted by Le Duke View Post
    This is what I read on the website on Chainrings.....
    •Convert your Specialized crank to SRAM 2x10
    •Available in the following options:
    •XX Chainrings & Spider for S-Works Crank 2639 (specialized)
    •XX Chainrings & Spider for S-Works Crank 2842 (specialized)
    •10-spd Chainring Set 38-24 with X9 Specialized GXP Spider 49 Chainline 104/64 BCD
    •10-spd Chainring Set 36-22 with X9 Specialized GXP Spider 49 Chainline 104/64 BCD
    •Convert your SRAM 2x10 crank to 38-24 or 36-22
    •Available with these options:
    •All Mtn Guard 38-24 with X0 GXP Spider 49 Chainline 104/64 BCD
    •All Mtn Guard 38-24 with X0 BB30 Spider 49 Chainline 104/64 BCD
    •All Mtn Guard 38-24 with X9 GXP Spider 49 Chainline 104/64 BCD
    •All Mtn Guard 38-24 with X9 BB30 Spider 49 Chainline 104/64 BCD
    •All Mtn Guard 36-22 with X0 GXP Spider 49 Chainline 104/64 BCD
    •All Mtn Guard 36-22 with X0 BB30 Spider 49 Chainline 104/64 BCD
    •All Mtn Guard 36-22 with X9 GXP Spider 49 Chainline 104/64 BCD
    •All Mtn Guard 38/24 with X0 GXP Spider 49 Chainline 104/64 BCD
    So maybe I got confused with the 49? being the same for both.
    Formerly of Kent
    Well, if they think the BB type is worth mentioning, perhaps it's worth looking into as a potential customer.
    Death from Below.
    Sep 2012
    Well when the mechanic at my LBS couldn't say for sure if there were any incampaitible differences, maybe that would have help avoiding this big drama. I'm just a student sitting in a class room right now eager to learn...
    Mar 2011
    the "49" on that table indicates a "49 mm chainline"
    Sep 2012
    Aahh....damn this is just one big mess. I found this on a different thread Difference in SRAM GXP and BB30 Spider? this will explain everything...bummer, so now got to find a spider that has GXP and 26/39
    Sep 2012
    Quote Originally Posted by irv_usc View Post
    So if both BB30 and GXP have a "49mm" the same chainline, where is the offset?
    So does that mean that there is problems with the spiderless chainrings between BB styles too?
    Quote Originally Posted by Slash5 View Post
    Yes. I know the MRP Bling Rings aren't rated to be used with a BB30 crankset. There are those that have made them work, but chainline often isn't optimal. Lots of examples in the Bling Ring thread.
  1. MRP Announces Sram Direct Mount Chain Rings (Spiderless) w/ Chainline off-set!
    By darrinw2001 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-27-2014, 01:55 PM
  2. Changing Sram 1250 chain rings
    By lastplace29er in forum 29er Components
    Last Post: 11-19-2012, 09:14 AM
  3. Replacing Sram 2X10 chain rings
    By BacDoc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-19-2012, 06:05 PM
  4. Sram xx chain rings
    By jackcoul in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-12-2012, 03:57 PM
  5. Newb: need advice on replacements for chain rings, cassette and chain
    By Porschefan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-20-2011, 01:53 PM
