Results 1 to 5 of 5
    Reputation: JetFuelOnly's Avatar
    Sram Cassette Compatibility
    I've got a 34t shimano cassette on now and was looking to upgrade to a 32t. My dad's got a sram powerglide 990 32t that I was gonna put on. The splines match up but it does not slide onto the hub. There seems to be an elevated groove upon which the splines sit in the sram cassette, but that's the only difference I could find. Should this cassette fit on the hub I have? Are the sram/shimano cassettes typically interchangeable?
    It doesn't get easier, you just go faster.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by JetFuelOnly View Post
    They are totally interchangeable for 8/9/10-speed.
    mtbtires.com
    Jan 2009
    It definitely should fit. Might take some wiggling to get it to slide on the freehub. I always put a light coat of grease when I install cassettes.
    I assume you know there is a wide groove that has to match up with the wide spline on the cassette?
    Thanks for the replies. It just took a little more effort to slide it on there. Wiggled it and it went on.
  1. Shimano SRAM cassette Compatibility
    By AUSTIN672 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-18-2013, 09:51 AM
  2. Replies: 0
    Last Post: 01-14-2013, 07:54 PM
  3. cassette/derailleur compatibility
    By MD_TX in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-17-2012, 08:09 PM
  4. Cassette compatibility
    By xianmacx in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-24-2011, 12:19 PM
  5. Compatibility questions - Shimano cassette/chain with sram 2X10
    By tjhanes in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-28-2011, 02:38 AM
