Results 1 to 3 of 3
    SRAM 900TT thumbies with 3x10
    I am still working towards a thumbies installation on a new build and through the help I have received here, I am planning to use the SRAM 900TT barcon shifters with Pauls thumbie mounts. However, I am installing a 3x10 and not a 2x10, so am wondering if there will be enough shifter range to support all three chainrings? I know that the left side shifter is friction only, so hopefully it will work.
    Killer of Chains
    Using them with SRAM derailures?
    The front should work, but don't hold me to it.
    The front is a friction shifter, and allows for a huge throw adjustment (30, 60 or 120 degrees), so yes, it will work with a 3x10 front. The Thumbie/TT500 is a great set up for SRAM x series derailliers, both front and rear.
