I'm wondering if anyone else has had this problem with their CB Mallets and found a fix:
The spring is moving sideways along the direction of the axle until the spring's tail makes contact with the inside of the main pedal casting. At this point the tail digs into the casting and stops the wings rotating. The wings will also stick in the open position after unclipping.
I've found that I can tap the spring back into a central position with a screwdriver and small hammer, but within a couple of rides it's moved back to digging into the casting again.
Looking at the pedal design, there is nothing stopping the spring moving sideways, other than simple friction on the wings. There's no locating stop.
The pedals have been back to 2Pure, the UK importers, who replaced the springs but ironically this simply moved the problem from the left pedal to the right!
I've done a search and can't see this problem coming up and quite a few of my riding buddies have the same pedals with no issues.
I can't see how to fix this. Any ideas?
