Results 1 to 6 of 6
    Specific crank bb questions...
    I'm going to go 2x9 or 2x10 on my bike. Need recommendos for a crank and bottom bracket combo that fits the following criteria:
    1. 51mm chainline on my Yelli Screamy means tight tolerances.
    2. Prefer 26/39 or 24/36 chainrings.
    3. Need bottom bracket that can handle wet and muck.
    4. Prefer set it and forget it maintenance (as much as possible).
    5. I'm a clyde: 255 lbs. I see lots of talk of ceramic bearings, enduro bearings, oversized bearings. Not sure what's the best for a guy my size.
    Was interested in e thirteen because of the larger bb spindle and large bearings in the bb, but I've read that they can make for trouble in wet weather.
    I don't mind spending a bit of coin--up to $300. And I don't mind buying bb and cranks seperate. Any help out there?
    Just a flesh wound
    Reputation: Prophet Julio's Avatar
    I don't know much about the newer external bearing BB's, but SKF makes a bomproof BB in ISIS and square taper. That said, there are a lot of good options out there.
    Real world Cycling has Enduro stuff. MTBTandems.com has the SKF stuff
    Good luck.
    My name is Chris and I ride a Prophet 650b with a Lefty.
    Thanks. Maybe because I posted on the weekend I haven't gotten much response. That, or I didn't simplify my question enough. Really, I just want a clyde bottom bracket that has a reputation for holding up to wet and muck. I know water and mud are the worst hazzards for bb's, but I wasn't sure if any one were better than the other. Here are the bb's most recommended here at mtbr:
    -Hope
    -Chris King
    -Enduro
    Another thing I don't know much about is bearings. What makes ceramic vs. steel vs. AL vs. bearing size preferable? Should a clyde be looking for a certain kind of bearing?
    Just a flesh wound
    SKF bottom brackets are made with a unique axial seal that makes them a good choice for wet and muddy conditions.
    MTBTandems sells them for tandem bikes. They have Cro-Moly and Stainless versions. I went full stainless 4 years ago. I ride the rocks, roots and mud of New England on a Cannondale Prophet. I would highly recommend the SKF. It is not for weight weenies. Mine is still as smooth and quiet as day one.
    Just a flesh wound
    Check out this link.
    http://www.mtbtandems.com/SKF.htm
    ups and downs
    SRAM X-0 and Noir 3.0 cranks are designed around a 51mm chainline.
  1. Trail specific Questions, Durango
    By eatmorecarp in forum Colorado - Western Slope
    Last Post: 08-23-2009, 09:18 PM
  2. Specific Yakima Rack questions...
    By a4racer in forum Cars and Bike Racks
    Last Post: 07-27-2009, 12:33 PM
  3. More specific XTR v XT questions...
    By Johnny Chicken Bones in forum Brake Time
    Last Post: 09-02-2008, 09:05 AM
  4. Please help me with stupid tire specific questions.
    By nachomc in forum Wheels and Tires
    Last Post: 01-08-2007, 02:39 PM
  5. Specific 575 Questions
    By mtnbkrdr98 in forum Yeti
    Last Post: 11-21-2006, 03:13 PM
