Results 1 to 10 of 10
    Specialized hardrock crank replacement/upgrade
    I recently purchased this bike and after about 15 miles the left crank arm started backing out and coming loose. It has eaten up some of the square on the crank arm. Where it won't hold anymore I'm looking for a cheap or the cheapest replacement crankset. I ride this bike daily. Any suggestions?
    Reputation: Shalom's Avatar
    Nov 2008
    You should be able to get a replacement non-driveside crank arm in either square or diamond from your LBS. A whole lot cheaper than replacing the entire crankset, and just as good.
    Fat-tired Roadie
    Nov 2007
    Double post. Check your other thread.
    Ok thx. Any idea what size crank arm it's a truvAtiv x-forge
    Nov 2008
    It should say on the crank arm, by the pedal thread. My guess is that it will be a 175mm. Probably safer to take the crank arm in to your LBS and just get them to give you a replacement. If you decide to order your own, just make sure that it is the same (ie diamond for diamond, or square for square).
    I looked on the crank arm and it only says e2b45x
    Nov 2008
    The measurement should be on the back of the crank arm. If not, you could always just measure it or take it in to your LBS.
    Reputation: 2FewDaysOnTrail's Avatar
    Decent crankset for $44 bucks here.
    Shimano Deore Crankset M510 at JensonUSA.com
    Salsa Bucksaw
    Trek Farley
    Niner Jet9 RDO
    Niner Air9 Carbon SS
    Rockhopper Comp SL
    Well I went ahead and ordered the m582 any idea what the average install price from a shop I's
    Fat-tired Roadie
    Nov 2007
    Should cost on the order of $15. If you need your bottom bracket shell faced, it could cost a lot more, though. Bringing in a bike clean always helps.
  1. Specialized Hardrock upgrade?
    By golfcart in forum Beginner's Corner
    Last Post: 07-23-2012, 04:31 PM
  2. Specialized hardrock xc crank
    By blazin05 in forum Specialized
    Last Post: 08-25-2011, 12:06 PM
  3. looking for a cheap replacement frame for a 2005 specialized hardrock
    By ou2mame in forum Bike and Frame discussion
    Last Post: 04-24-2011, 12:09 PM
  4. disk brake upgrade for '07 specialized hardrock???
    By bietsch in forum Beginner's Corner
    Last Post: 10-03-2009, 09:58 PM
  5. Specialized Hardrock Fork Upgrade
    By doajump in forum Beginner's Corner
    Last Post: 01-26-2006, 05:06 PM
