    Some pointers on adjusting Shimano XT Shadow rear mech screws
    Hi everyone
    Can some of you intellegent mechanic types give me some pointers on adjusting my rear mech? (apart from pointing towards my local LBS)
    Situation is this.....
    New bike new rear mech new cables etc....
    approx 40 miles of riding and my rear mech wont move into highest gear closest to wheel, theres been no knocks so i assume just needs adjusting....ive watched some youtube videos and this is what ive done.
    removed cable from rear mech and pushed rear mech across the cassette it wouldnt move to largest cog. attached cable again.
    adjusted the screw till the mech changes gear across all the range without a problem,
    This i assume is all i have to do?
    Reason i ask is i had to turn the adjustment screw probably best part of 4 or five complete 360 revolutions so now it sticks out quite a way compared to the low gear adjustment screw....
    Thanks in advance!
    Reputation: J.B. Weld's Avatar
    Limit screws don't have much to do with actually tuning the gears, they only stop the derailleur from moving past the high or low gear and prevent the chain from falling off. You should be able to look at the limit screws and see it hitting the stop in either high or low gear. Here is mine in low gear showing the end of the screw contacting the stop.
    If you have a gap between the screw and stop when in high gear then the cable tension is what is preventing the chain from falling off, and the screw should be re-adjusted. If not then you're OK. Once the limits are set then the cable tension is what actually adjusts the gears, and unless the hanger or something gets bent you won't have to mess with the limits again.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Andrewfuzzy View Post
    Hi everyone
    Thanks in advance!
    I am reading that you are turning the high limit screw to try to get the chain to shift to the largest cog.
    The large cog is the low gear ratio, easier to pedal. You are turning the wrong screw.
    mtbtires.com
    Like Shiggy said, you are probably turning the wrong screw, but the limit screws can still be different heights when properly adjusted.
  1. Replies: 7
    Last Post: 11-28-2012, 04:08 PM
  2. XTR shadow plus rear mech shifting issues
    By phantomx0_1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-05-2012, 09:49 PM
  3. Shimano Rear Shadow = Junk
    By daggert in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-30-2011, 10:57 AM
  4. Difficulty adjusting Shimano rear hub
    By Dictatorsaurus in forum Wheels and Tires
    Last Post: 03-09-2011, 05:24 PM
  5. Shimano XTR M980 Shadow 10 Speed Rear Mech and 9-speed system...
    By xr_mtb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-24-2011, 08:08 PM
