    SLX-rear derailleur and Dura-Ace Shifters
    Dear all,
    I plan to update my Surly Crosschecks drivetrain. As I am very happy with my mountainbikes SLX components, I´d like to get a 9-speed SLX rear derailleur and a SLX crank (FC-M660). I would prefer to use downtube shifters; the rear derailleur should work with dura ace DT shifters (9 speed), shouldn´t it? Would it be possible to get rid of the granny ring of the crank and use a 2-speed front derailleur with the dura ace shifter?
    thanks
    Björn
    Reputation: Nater's Avatar
    Yes, the SLX rear derailleur and the Dura Ace shifters will play well togther.
    As for the cranks, I think you'll be better served if you use a road crank on the Cross Check. I think the chainline will be too far outboard if you turn a SLX into a double using the middle/big rings. I'd get a compact road crank instead.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by brettsportler View Post
    Dear all,
    thanks
    Björn
    Yes, works fine. May need to add a barrel adjuster to the system.
    Agree with Nater about crankset chainline.
    mtbtires.com
    Thanks, I guess I will really go with the new 105 compact crank.
    Best,
    Björn
  1. Dura-Ace rear derailleur compatibility
    By palmix in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-13-2010, 08:25 PM
  2. 1x9 Dura-ace or XTR Rear Derailleur, Short of Long Cage
    By wensiaw@pacific.net.sg in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-21-2007, 07:36 AM
  3. Dura-Ace Rear Derailleur Question
    By dualsport650 in forum Weight Weenies
    Last Post: 06-08-2006, 01:43 AM
  4. Dura Ace rear derailleur - with 8 speed?
    By top_ring in forum Weight Weenies
    Last Post: 04-13-2005, 08:59 AM
  5. Dura Ace rear derailleur - with 8 speed?
    Last Post: 04-11-2005, 12:52 PM
