Results 1 to 5 of 5
    Feb 2013
    Slx on a heckler
    I'm thinking of buying a shimano six group set for my heckler I'm building...
    first question I wanna run a single ring up front so I should buying the 3 up front right?also 170 or 175 crank length ?
    next question what cassette should I run ...11/34 or 11/36
    bike is gonna be used more for going down then up
    I have a SC Nickel with a 11/36 cassette, I also have shorter legs so I use a 170mm crank arm.
    where did you find your groupset. ebay?
    Feb 2013
    Blueskycycling
    Feb 2013
    Crank arm length depends on your inseam/leg length; also on your cadence preference; also to some extent on terrrain (some follks on rocky/rooty East Coast stuff want fewer pedal strikes, and go with shorter crank arms).
    Since you're descending more, shorter cranks may make sense.
    Similarly with the cassette, you probably won't "need" the 36 cog if your emphasis is descending; but I've always preferred to have a lower gear option, for times when I do have to haul an AM rig up something steep, especially on a 1X10.
  1. Heckler 6.1 vs 6.2?
    By williamj in forum All Mountain
    Last Post: 06-24-2013, 10:35 AM
  2. Heckler.5
    By J.R.A. in forum 27.5
    Last Post: 05-28-2013, 08:50 AM
  3. My heckler
    By mtb0187 in forum 27.5
    Last Post: 08-17-2012, 01:16 PM
  4. Is the Heckler enough?
    By SoWal_MTBer in forum Santa Cruz
    Last Post: 06-22-2012, 10:03 AM
  5. SC Heckler
    By Tonka4x in forum Santa Cruz
    Last Post: 12-24-2011, 11:10 AM
