Results 1 to 6 of 6
    I'm Slow
    Reputation: paulrb02's Avatar
    SLX 2x9 and Medium Cage X.9
    So I am upgrading to the SLX 2x9 crank and I was also going to purchase a new rear derailleur at the same time. But should I get a med cage x.9 or the long cage. I did the math from the which is 37T but I was wondering if anyone is running a similar setup and which one would be best to use. Any Pros, any Cons, anything to lookout for.
    Setup: Will be SLX 2x9 at 36-22 t and a 11-34 T cassette
    Thanx in advance for any help.
    Former Bike Wrench
    I've been running medium cage rear derailleurs on my 2x9 setups for years, they work fantastic with both 36/22 and 34/22 with an 11-34 cassette.
    AZ is offline
    Reputation: AZ's Avatar
    I run the exact same set up , works very well .
    Reputation: chuckie33's Avatar
    What are the advantages of running a medium vs. long cage on a 2x9? I'm considering converting to 36/24 with 11-34. Currently have an X.0 long cage. I'm assuming the shift is a little crisper but with the right chain length a long cage should still work just fine and still be plenty crisp when shifting.
    If you ever see a turtle on a telephone pole, remember he had help getting there. Is there anything beer can't do?
    Reputation: 1-bar's Avatar
    Here is your answer. This is a 2x9 w SLX fd , med cage rr XO w a 24/36 chainring setup. 2x9 setup
    your plan sounds solid.
    OPEN Cycles One+ in stealthy black
    Reputation: PissedOffCil's Avatar
    Oct 2007
    I used to run a short cage X9 on a 26-36 with a 11-34 and lost 1 gear. I'm sure the medium cage works but going with a short cage might also be doable as long as you watch out carefully for cross chaining.
    Yes this is an extreme case and bad advice and I wouldn't do it because you would end up losing 3 gears I reckon. I'm just pointing it out as I wait after the computer (read bored)...
    Check out my SportTracks plugins for some training aid software.
