Page 46 of 46 FirstFirst ... 364243444546
Results 2,251 to 2,297 of 2297
  1. #2251
    Mar 2014
    Show pics of your 1x9 setup
    On a 9 speed. Unsure how to go about that. You would need to find a cassette that you can remove a single sprocket. Probably the 17t. I'm using 1x10 now with a one up 42t. Check ebay often you can find wolftooth, one up and e13 ring quite cheap on there.
  2. #2252
    Mar 2013
    I have a cassette that I believe I can remove a single sprocket. These e13 and oneup and wolftooth all appear to say 10 speed. Can it also be used with 9 speed?
  3. #2253
    Mar 2014
    I don't see why not. My crankset said 10spd and I used it 1x9 for ages before switching.
  4. #2254
    Mar 2014
    I would think a 9spd chain will work ok.
  5. #2255
    kneecap
    Id be real interested if that works. I was under the impression that 10 sp. cassettes had a closer distance between each ring compared to a 9 sp. So, you'd have to have a 10 sp. shifter as well?
    Then of course that wouldn't be a 1X9 anymore.
  6. #2256
    Mar 2013
    as I understand it, it should work. essentially I will remove some middle cog from the cassette to make room for adding the 40t cog. Some custom shim might be required to back the 40t off the (existing) 34t, but I think that shim might be included with some of these 40t gears.
  7. #2257
    meow, meow.
    Reputation: J. Random Psycho's Avatar
    Quote Originally Posted by kneecap View Post
    Let's just pretend this thread is called 1xN and is dedicated to any single front ring, rear derailer based, chain drivetrains.
    26" rigid SS 4130 BB7 nylon-flats ESI latex-tubes non-lubricated-8spd
  8. #2258
    There is a discussion about using a Absolute Black 40T ring with a 9 speed cassette that starts with this post:
    WolfTooth Components Thread
  9. #2259
    RIP Friendgirl
    Reputation: Bordershy's Avatar
    My 1X9
    [AT
    28T granny, 36-12 9sp cassette, Saint SS derailleur, Jump Stop & Stinger chain guide + Blackspire Granny God Bash Ring.
    Can substitute a 26T ring for long climbing days.
    TACH=CONFIG]945834[/ATTACH]
    Attached Thumbnails Attached Thumbnails Show pics of your 1x9 setup-img_0607.jpg
    SPD pedals are an absolute menace to the well-being of the world, and ought be banned immediately.
  10. #2260
    meow, meow.
    Bordershy, nice! What I like the best there is that no exotic parts are used.
  11. #2261
    RIP Friendgirl
    The Blackspire GrannyGod was a tough find. I did put a double bend in the stinger bracket to put the chain in the grove of the roller.
    I would love to build a 40-11 9sp cassette if it wasn't such a pain money wise.
  12. #2262
    kneecap
    bordershy, what cassette did you use for your conversion?
  13. #2263
    RIP Friendgirl
    Hg-61 36-12
  14. #2264
    Reputation: tundratrader's Avatar
    So I currently have a 2x9 setup. I don't need my highest gears. If I went absolute black 26t 64bcd chain ring. What would I need out back? I currently have a x7 with 11-34 cassette. I was looking to go 1x10 but 1x9 would work fine. If I can get a new cassette and knock the bottom ring off and use a different lock nut awesome. This thread is huge so sorry if this is repeated.
  15. #2265
    Quote Originally Posted by TalMiz View Post
    Yep I tried, it worked, but on moody trail the rear derailleur is tossed. The lower roller just keeping the chain tight.
    I know about the SRAM shifter with Shadow+ combination, that is my next upgrade.
    Will a 9 speed sram shifter work with this? That would save if I only had to get the clutch derrailuer. This is the first I have heard of this. I thought Sram 1x1 actuation had to work with Sram. Please inform me more about this. Looks like I have lots of reading to do now that I have found this thread.
  16. #2266
    Armature speller
    Sep 2004
    Re: Show pics of your 1x9 setup
    Quote Originally Posted by tundratrader View Post
    Yep, it works.
  17. #2267
    NedwannaB
    Reputation: JMac47's Avatar
    Quote Originally Posted by kevbeer View Post
    I have camber comp fsr 26er with 9speed 11-34t cassette in back. i am looking to go1x9 with 11-40t in back. What is the cheapest drop in 40t cog? I am not looking to drill holes.
    No real "cheap" way to convert a 9spd with an add on cog. Least "inexpensive" way is a Shimano HG61 12-36t 9 spd cassette and adjust your front ring down a size to give you the same gear as you would with the 40t granny setup.
    Wait whuuut, who did he tell you that!?!?....
  18. #2268
    NedwannaB
    Yes. SRAM 9 spd works to shift a Shimano 10 spd Dynasis clutch derailleur using a 9 spd cassette and chain. Most only need a slight adjustment on the cable clamp attachment. Lots of posts in here about that setup.
  19. #2269
    Nov 2014
    Oneup 30t
  20. #2270
    DaFaJa
    Reputation: Corbinworks's Avatar
    Some really clean set up's
    LBS just told me that there is no way to run a 1x9 set up on my 06 Specialized XC, So after seeing this thread I want to do it now!
    First off, What rear derailleur on a budget & how do I know what size I would need?
    I still have the stock 3x crank in with the large ring swapped out for a bash guard..I want that clean lighter look..Thanks for any help in advance!
    2012 Trek Superfly 100 Carbon /Sid W/C XX / Fox CTD RP / xx1 / xo type2 / Stans Flows
    Tampa FL USA
  21. #2271
    Reputation: fire_strom's Avatar
    New LBS.
  22. #2272
    Mar 2014
    Wen I went 1x9 all I did was stuck a NW on the front. Same stock rear de and cranks. Worked fine.
  23. #2273
    DaFaJa
    Quote Originally Posted by Ross1200 View Post
    Really?
    I will have to try this...Thank you!
    Tampa FL USA
  24. #2274
    Mar 2014
    Yea. Stuck a 32t NW where my old middle ring was. No bash. Fitted the 104 BCD fine. Ran like a beauty.
  25. #2275
    DaFaJa
    Hard Tail or Full Suspension?
    Tampa FL USA
  26. #2276
    Mar 2014
    Hardtail 29er
  27. #2277
    DaFaJa
    Any one know if this will work with a FS 26er?
    Tampa FL USA
  28. #2278
    Armature speller
    Sep 2004
    Quote Originally Posted by Corbinworks View Post
    Did on mine.
  29. #2279
    DaFaJa
    Quote Originally Posted by NordieBoy View Post
    Did on mine.
    With no other mods?
    Tampa FL USA
  30. #2280
    Armature speller
    Sep 2004
    With no other mods?
    2011 Blur XC
    32t Narrow Wide and X7 and 11-34 rear with the chain resized to give most tension I could safely get allowing for suspension travel.
  31. #2281
    NedwannaB
    Wheel size has no bearing on this. Now the type of suspension might, yes.
  32. #2282
    Nov 2014
    Hey guys, thought I could ask here instead of creating a new thread; I have Shimano Altus 3x8, I'm thinking of buying the Shimano Saint Crankset to go 1x8. Do I need anything else? My rings are riveted so my only option (well, I don't want to drill out the rivets) is to get a new crankset.
  33. #2283
    NedwannaB
    Quote Originally Posted by Ceps View Post
    As long as the new ring can run an 8 spd chain.
  34. #2284
    Nov 2014
    Ohh well I feel stupid, thanks god I asked. Sorry I'm new on this xD. Would this work: Shimano Deore 10 speed s+ r d (says dyna-sys), 10 speed casette (CS-HG62), Zee shifter and Saint crankset?
  35. #2285
    Reputation: cyberavner's Avatar
    Any 8,9 or 10 speed chainring will work with a 8 speed chain, so you can pretty much install any crankset with any chainring and it should work with your with your current setup.
    You may want to also change the chain to a 9 or 10 speed if the 8 speed chain is not flexible enough and gives you trouble in the extreme high or low gears of the cassette.
    If your current crankset handled your riding then a Saint is probably overkill and any Shimano mountain crankset will do the job.
  36. #2286
    Nov 2014
    Quote Originally Posted by cyberavner View Post
    Any 8,9 or 10 speed ring will work with a 8 speed chain, so you can pretty much install any crankset with any chainring and it should work with your with your current setup.
    You may want to also change the chain to a 9 or 10 speed if the 8 speed chain is not flexible enough and gives you trouble in the extreme hi or low gears of the cassette.
    If your current crankset handled your riding than a Saint is probably overkill and any Shimano mountain crankset will do the job.
    Nice Thanks, and yes is definitely an overkill but a deore crankset(ie) is only $10 cheaper haha
  37. #2287
    Mar 2014
    I'm using a saint crank on a 1x10. Def overkill but I like the security that it ain't gonna break being a heavier weighted man.
  38. #2288
    Feb 2013
    Here is my 1x9 conversion, with a little help from Wrath of Khan, who posted a while back on his conversion on his similar bike.
    It is a 2001 Specialized Enduro, with BETD linkage and many other upgrades. I switched out the old E-type BB with a regular, old school taper spindle BB so I could use my old cranks. The Raceface 30t NW ring fit perfectly. I got the bolt shims, but ended not needing them, since the chainring bolts I had (also raceface from a set of Turbine rings) fit perfectly.
    I am still using my original XT rear rear d/r (non clutch).
    It all works very well, super quiet, no skipping and so far, no dropped chains. Even on some rough, rooted trail, no issues.
  39. #2289
    Jan 2015
    Rockhopper 1x9
    Hi everyone I'm new to this forum but been lurking for a long time.
    Thought I would share my 2008 Rockhopper that I converted to 1x9 a year ago. 32 tooth RF N/W ring, new SLX 11/34 cassette and new chain is all I added. lost about 600g losing all the other stuff.
    Kept the deore long cage RD with no chain retention device and only dropped the chain on gnarly descents. Borrowed the Sram x9 short cage RD and shifter off my downhill bike for a while and that made a huge difference, crisp shifts no dropped chains.
    Ive had the deore RD back on now for about 6 months and not dropped a chain once, even in the same places that it used to fall off! Weird. This setup has covered just over 1000kms and going strong.
    Here are some pics when I first installed the gear.
  40. #2290
    Aug 2013
    Here's my Dexter Weight Weenie build, SRAM 1 x 9!
    X0 Brakes, Derailleur, Grip Shifter (1 x 9, 11-34 XTR cassette)
    Next Sl Cranks, 26t single. Made for climbing. I can live with 26/11 at speed.
    SID RLT Dual Air
    Fox RP23 shock(standard)
    Thomson post
    Eggbeaters, to be upgraded to Xpedo Ti/Ti (-60g)
    EC90 wheelset
    Stan's Maxxis Larsen Exception Silkworm TT FR:2.1 R:1.9
    Ashima Aireon rotors
    Plastic bottle cage(bontrager)
    Ritchey foam grips(awesome!)
    Selle Italia Saddle (220g, nothing special, may be upgraded)
    BSA30 sleeve to nix BB30
    Soon to be under 22lb.
    Apologies for the one sideways pic, computer deficient skills.
    Rides like a dream, only gripe is a bit of bob standing and mashing, would like RP23 tuned to actually lockout, right now lockout means nothing! Typical RP23 problem...Frame was exactly 6.02lbs bare, medium size. Rides faster than my old On One Scandal hardtail when climbing! I can't really explain why, but it does, it seems to almost self-propel itself a little, don't know why! Love it.
    Show pics of your 1x9 setup-20150217_164614.jpgShow pics of your 1x9 setup-20150217_164652.jpgShow pics of your 1x9 setup-20150217_164705.jpgShow pics of your 1x9 setup-20150217_164625.jpg
  41. #2291
    Nov 2013
    My current set up 30t/12-36 i like it so far
  42. #2292
    Nov 2013
    Quote Originally Posted by dhindo View Post
    replaced shifter and r/d with sram x7...i just love the 1:1 shiftingShow pics of your 1x9 setup-750.jpg
  43. #2293
    NedwannaB
    replaced shifter and r/d with sram x7...i just love the 1:1 shiftingClick image for larger version.
    Dang that looks fast, like a fighter jet on the tarmac ready for take off!
  44. #2294
    Apr 2015
    technically a 1x8...
    09 Gary Fisher Wahoo Disc - everything replaced except the frame
    by civsix, on Flickr
  45. #2295
    Mar 2015
    Wifey's bike as it should have come from the factory. RF n/w cr. Never skips and she thinks it's pretty. The stock 11-34 cassette is fine. She never used the 34, it's pretty flat around here. But we went with 165mm cranks, which is like going down a tooth in the back, so it worked out.
    In terms of cranks, there are some nice RF units on ebay for about $140, with ring and bb. However I think the best deal out there right now are some XT Deore cranks on pricepoint for $130 with bb. Got some for my bike, put the rings up on ebay, they are going for $11 right now. Plus I could sell the bb. Winds up being a great deal, and those XT crankarms are niiiiice, they feel lighter than the RF units. Love the Hollowtech, just don't forget to order that $2 "bearing preload bolt" tool.
    Wellgo magnesium pedals, just a stupid good deal. Light, grippy, pretty colors. Cheap enough to buy a new pair every season.
    Attached Thumbnails Attached Thumbnails Show pics of your 1x9 setup-image.jpg
  46. #2296
    Reputation: Sambones80's Avatar
    Sep 2016
    30t RF NW & 11-36 SunRace cassette. I tried an X-9 short cage but it wouldn't clear the two largest cogs no matter how I adjusted the b-screw and it shifted like crap so I went back to my original long cage and haven't dropped the chain yet.
  47. #2297
    Hey I am curious if youguys have a suggestion to run a 9 speed rear cassette with a short cage derailleur. I have a partially used xtr cassette sitting in a box (from when I went X1) that I wanted to put on my daughters bike. She had an 8 speed clunker drivetrain that only went to 28t in the rear. I tried putting an old XT derailleur I had on there, but the 20" wheels are so small that the derailleur is almost hitting the tire. I thought I could just get a short cage, but they seem rare now. Then I saw the Zee derailleurs that seemed to fit the bill (FR) version, but of course they are for 10 speed.
    Reading/searching led me to believe it may work with a sram shifter and maybe a spacer or maybe not, but a lot on here seem to have the saint der and I was wondering if you are just using a SRAM 9 speed trigger and whether it is the same as the zee or not.
    I could try the XT derailleur, but it is from 13 years ago and I need new pulleys anyway to make it work decent so I wanted to get something else instead of dropping money on something that would just go away. Anyway if anyone has the cliff notes for this I would appreciate it.
    Edit:These links have enough info I think.
    SRAM 9 speed twist shifter + Shimano 10 speed derailleur
    Anyone using 9-speed Sram shifter with Shimano 10-speed derailleur? | Ridemonkey Forums
