Results 1 to 5 of 5
    Should my rear derailleur rotate?
    I've been having some poor shifting. The bolt attaching my rear derailleur to the frame was loose enough to allow the entire derailleur to rotate on this pivot. It seems to have some kind of a spring mechanism, so I thought this was correct. But now I'm not so sure. So I tightened the bolt up. Which way is correct?
    I have an XT traditional rear derailleur.
    Thanks,
    Jamie
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by TiCoyote
    Thanks,
    Jamie
    the mounting bolt should be tight and the derailleur should be able to pivot.
    mtbtires.com
    Okay, but when I tighten the mounting bolt, it won't pivot. What am I doing wrong?
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    torque the bolt to 75 in/lbs
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
    It seems like there are two black plates that should slide past each other to allow the thing to pivot. As I tighten the bolt, they get closer together, and when it's tight enough, they no longer pivot. I don't have this problem with the derailleur on my road bike.
