Results 1 to 8 of 8
    Reputation: cman8's Avatar
    Short or Medium?
    Is this a short or medium cage RD? Can you tell? Any help appreciated. Thanks
    I'd guess short.
    My Long cage X7 is 4" between jockey wheel bolts.
    My medium cage X7 is 3" between jockey wheel bolts.
    Hope this helps from SRAM's webpage. Different rear D designs may vary a little bit, just not too much:
    10 speed only
    Material Aluminum alloy links and forged B-knuckle, High Strength Grilon® P-knuckle, sealed cartridge bearing upper pulley, Aluminum long/medium cage/composit short cage
    Weight 204 grams (medium cage)
    Outer Cage 6061-D-Stamp , Composite
    Compatibility Exact Actuation 10 speed
    Inner Cage 6061-D-Stamp , Composite
    Bearings Bushing
    Cage Sizes 55mm, 75mm, 99mm
    Max Tooth 36 tooth compatible
    Technology Highlight(s) Exact Actuation
    Hope that helps.....
    Thats for a 10 speed. Mine is a 9 speed which is why im trying to figure out. Thanks.
    Quote Originally Posted by Slash5 View Post
    I'd guess short.
    Do you measure center to center?
    Reputation: ColinL's Avatar
    Feb 2012
    It won't vary that much because 9 and 10 spd RDs are very similar save indexing. If you measure you should come up with something near the values listed above. And I'd guess short cage as well, FWIW.
    Im thinking its short cage too but the person I bought it from says its a medium. I know they will help out if its a mistake but I dont want to go back and try to get this resolved if its a medium cage in fact. It just looks too small to me to be a medium. I weighed it and its 202 Grams.Do you measure the cage from the outside or inside?
    Quote Originally Posted by cman8 View Post
    Just a rough measurement with a tape measure, bolt to bolt - does 1/4" matter?
    Found this on the web:
    "X-9 10-speed rear derailleur on their website - they are listed as 55mm, 75mm, and 99mm for the short, medium, and long versions."
