Results 1 to 12 of 12
    Bonking ... not feelin' well Shimano Zee Clutch Lever keeps coming loose turning clutch off - advice?
    Hi all. I'm running a Zee rear mech on my bike, the Free ride wider gearing version (not downhill) and is paired with a Shimano XT 11-36 cassette and an XTR shifter all 10 speed. My zee rear mech has the gold clutch lever but it has never felt particularly stiff.
    Tonight I went out on the trail and as an expermient took my front chain guide off to see if I could get away with just the Zee rear mech to retain the chain. I dropped the chain like 5 times in horrible places too. At first I thought ok, the front chain guide is obviously required for my type of riding in addition to the Zee clutch rear mech, but then I noticed towards the end of the ride that twice in a row when the chain dropped, I checked the Zee Clutch lever and it was in the OFF position.
    I am now wondering if the Clutch lever has been coming loose and caused the chains to drop. Or would the lever move to the off position when the chain comes off anyway as a safety thing due to some internal load change when the chain comes off?
    I checked my mates Shimano XT Clutch lever (not Zee) and his XT one is slightly stiffer and a little more positive once pushed home to the ON position, but not that much more. A bit of a shame as I love it otherwise.
    Is it possible to tighten this lever up? I fail to see why I should improvise with tape or a tie to hold it on. Seems silly.
    undercover brother
    Reputation: tangaroo's Avatar
    I had a Zee, it broke and I am awaiting my warranty replacement, so I replaced it with an XT. The Zee lever was definitely a little flimsy compared to the XT, but it never came loose and dropped to the off position. I would call Shimano and try and get it warrantied, althought the Zee is on backorder forever...
    Backorder with...Shimano? As in...trying to get a replacement Zee from the manufacturer direct and they can't supply one? I'm in the UK if this makes a difference.
    undercover brother
    Ironically, when I got home from work it was sitting on my doorstep, but it was the DH version and not the FR, so I will be shipping in back to Shimano... But the rep told me they were back ordered at Shimano.
    Jul 2014
    Hi there.
    I've been having exactly the same problem with the clutch lever on my new (2 months' use) FR Zee on a 1x10 set-up using a narrow/wide chainring with no chain guide.
    I've yet to drop the chain but have noticed the lever has flicked itself to the 'off' position on numerous occasions, especially after blasting through a rock garden.
    I too would appreciate any feedback on this and wether or not its possible to tighten the lever?
    Lets hope we get an answer to our problem. Cheers
    Mar 2013
    I'm experiencing this same issue on my Saint derailleur at the moment. Sometimes it's fine for a whole descent and sometimes it switches itself off again pretty quickly after resetting it (chainslap noise is very noticeable when it switches off). Anyone found a solution? Increasing or decreasing clutch tension maybe?
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Clutch tension sounds like it's set too low. Have you checked the tension?
    Check this out...
    http://forums.mtbr.com/drivetrain-sh...87.htmlhttp://
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    smartass
    Reputation: amish_matt's Avatar
    The clutch is both adjustable and replaceable. Universal has them of $8.99. It's a really easy fix.
    https://www.universalcycles.com/shop...27&category=74
    Mar 2013
    Quote Originally Posted by Cleared2land View Post
    The weird thing is that before switching the derailleur onto my new frame 4 weeks ago I cleaned it all up and increased the clutch tension just a little. Like you suggest, I would think that more tension would keep the clutch in the ON position better but I'm experiencing the opposite. I'll try less tension first just out of interest, but increasing the tension more than it is currently sounds a logical fix.
    Magically Delicious
    Shimano Zee Clutch Lever keeps coming loose turning clutch off - advice?-shimano-clutch-document.jpg
    Name:  Shimano Clutch Adjustment.PNG
    Mar 2013
Name:	Shimano Clutch Document.jpg
    Very useful, but my torque wrench doesn't measure in the unscrewing direction. I tightened the clutch tension half a turn for now and the lever feels like it hsould stay in position a little better. Trail test tomorrow.
    Mar 2013
    Update on this old post. Tightened my Saint clutch by half a turn; better but the lever still loosened during riding. Another half turn tighter fixed it.
  1. Suitable Grease for Shimano Clutch?
    By half_man_half_scab in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-20-2014, 07:09 AM
  2. Has Anyone Else Broken a Shimano Clutch RD?
    By Salespunk in forum Ibis
    Last Post: 06-03-2014, 01:47 AM
  3. New Clutch Derailleur for 1X10. SRAM or Shimano?
    By integral in forum All Mountain
    Last Post: 05-13-2014, 02:44 AM
  4. Replies: 6
    Last Post: 10-15-2012, 10:11 AM
  5. New Clutch Derailleur for 1X10. Shimano or SRAM
    By integral in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-30-2012, 09:21 AM
