    Jun 2016
    Shimano XTR SL-M980A Rebuild?
    Hi, something broke apart in three places inside my left shifter. Is this the pawl? Can it be replaced? If so, what's the part number? Thanks.
    B A N N E D
    Quote Originally Posted by XX hihat XX View Post
    Have a look on the exploded diagram: http://si.shimano.com/
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Not showing a close up of the failed part, I'm thinking that unless you're able to fabricate what appears to be a broken rivet, then you're SOS on a replacement part for that. If this shifter isn't under warranty, I'm guessing your choices are limited.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Mr. Buck E. Fikes
    Reputation: Oh My Sack!'s Avatar
    XTR is a 3 yr warranty, IIRC. Just sayin'...
  1. XTR shifter (SL-M980A) Handlebar mount dimensions
    By aborgman in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-13-2016, 10:15 AM
  2. Replies: 3
    Last Post: 12-15-2014, 04:29 AM
  3. Shimano BR-M775 Hydro Brake Rebuild
    By aero901 in forum Brake Time
    Last Post: 04-04-2014, 12:06 PM
  4. Shimano PD-M647 pedal rebuild
    By LBDjump in forum Tooltime
    Last Post: 10-10-2011, 06:11 PM
  5. Rebuild Shimano XTR Disc - WH-M965
    By Hesteskænderen in forum Wheels and Tires
    Last Post: 09-26-2011, 09:27 PM
