Results 1 to 8 of 8
    on my 3rd wind...
    Reputation: SingleTrackHound's Avatar
    Jul 2003
    Shimano XTR M952 crank/chainring compatability
    I own a Shimano XTR (older style) M952 tripple crankset with 4-arm spyder. I am in need of new middle and granny chainring as they are worn. Big chainring is fine as they don't get used often. Question is, since chainring for M952 cranset is hard to come by, what other brand/model/type middle and granny chainring other that Shimano XTR can I use it for replacement? Thx.
    Chrome Toaster
    Reputation: Hecubus's Avatar
    I believe any 4 bolt standard ring will fit the older XTR. Keep in mind the 952 used standard size rings (34-24) which are not that easy to find now that compact 4 bolt is more standard.
    on my 3rd wind...
    Jul 2003
    Quote Originally Posted by Hecubus
    I am not sure the what the diff. between standard & compact size ring are. If I accidently got compact middle & granny ring instaed of standard, they won't fit into my XTR M952 crankset with orignal leftover large chainring? Thx.
    Do It Yourself
    Reputation: Homebrew's Avatar
    The bolt pattern is 112mm/68mm optimized for the 34T and 24T. You can get them in Salsa and possibly Black Spire (used to make them anyway).
    For example...
    http://aebike.com/site/page.cfm?Affi...=30&SKU=CR4407
    The granny might be a bit tougher. I can't find that one right now. You might have better luck with some Googling.
    Long Live Long Rides
    Mar 2005
    COOL BUZZ & TASTY S-TRACK
    Reputation: spacoli's Avatar
    I have a new full set if your interested
    I know its been weeks since you posted this but, I just sent you a PM. Check it out.
    I have a new full set if your interested.
    Quote Originally Posted by SingleTrackHound
    I can fix it............... my dad has an awesome set of tools
    Mar 2005
    Price?
    Check your PM
    Check your PM
    Quote Originally Posted by buffallodan
    Price?
  1. New to the sport, need bike :)
    By iLLestOne in forum Bike and Frame discussion
    Last Post: 05-13-2005, 06:28 AM
  2. Which shifters XT (M750) or XTR (M952)?
    By petchia in forum Weight Weenies
    Last Post: 01-25-2005, 07:49 AM
  3. using shimano xtr 2003 rear derail. with deore mega-9 shifter
    By m4dj4ck in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-17-2004, 02:31 AM
  4. non shimano XTR chainrings
    By DJL in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-19-2004, 07:38 AM
  5. XTR M950 vs M952 Shifter Pods. Any difference? xpost
    By L-Dogg in forum General Discussion
    Last Post: 07-12-2004, 04:00 PM
