Results 1 to 9 of 9
    discombobulated SuperModerator
    Jun 2005
    Shimano XT RD-M750
    Snapped it today.
    Going by the model #, do I even need to worry about hi normal etc etc.?
    Simply match the part # and they will be the same?
    CDT
    ups and downs
    RD-M770 would be the current low normal (rapid rise) model, the only other thing to match is the GS or SGS cage length.
    Jun 2005
    GS being short cage, SGS long cage?
    CDT
    ups and downs
    Yep.
    Jun 2005
    Would the M772 Shadow GS/SGS work too? I can move down to a shorter cage, as I run w/o the big ring...
    CDT
    Shadow variants are technically cross-compatible (and are always top-normal). The return spring is a bit stronger. What type of shifter do you use?
    ups and downs
    Now you've opened the Rapid Rise high and low normal can of worms, the 750 was low normal (rapid rise) so if you use the Shadow or standard 771 derailleur your gear sequence at the shifter will be reversed.
    Quote Originally Posted by rockyuphill
    True, and I think Shadow does go best with conventional RapidFire Plus shifters (as opposed to dual-control or twist).
    I see this guy has a used XTR RapidRise-style for $50, if RapidRise is desired: http://classifieds.mtbr.com/showprod...t=32166&cat=13
    I have a lightly-used XTR RD-M972 SGS I'm trying to sell (long-cage Shadow, therefore top-normal), PM if interested.
    Jun 2005
    Quote Originally Posted by mechBgon
    Shimano...SL-570. Standard LX stuff?
