Results 1 to 3 of 3
    Apr 2005
    Shimano XT Hollowtech installation...
    Hi guys im installing a xt Hollowtech crankset and i have a question, is there any special position to put the crank arm into the bottom brancket or it will fit in any position.///
    I read that you have to Keep the raised spline aligned at the top 12:00 position on some spline bb but i dont know if shimano is the same or not.
    its a Shimano XT FC-M752 Hollowtech with a shimano ES-71 BB
    thanks
    Quote Originally Posted by sebastian21
    The splines on your BB are all the same, therefore it doesn't matter how you orient the crank with respect to the BB spindle. (You do want the cranks to be 180 degrees apart though. )
    Apr 2005
    thank
    OK, thanks
